I have a 3.5s and a MMU3 what is the best way to by pass MMU3
Dschiri1
(@dschiri1)
I have a mk3.5s and a MMU3 what is the best way to by pass MMU3.  I'm having issues with my MMU3.  I only get about 50% success rate.
When it works I get a pretty good result.  But damn it is finicky.  The MMU3 turns my work horse into a temperamental cat.  Is there a way to by pass the MMU3 and not get error on the screen about not compatible code.
What i do is remove the PTFR tube from  hot end and turn off MMU3 in settings.  Use prusa slicer settings for mk3.5 and not i3mk3.5 MMU3.
When I load the code, machine it says not compatible code but the code runs fine.  Is there a setting I'm missing?  I wish that there is a profile in slicr with MMU3 installed but turned off.
Respondido : 10/10/2025 6:25 pm
