I have a 3.5s and a MMU3 what is the best way to by pass MMU3
I have a mk3.5s and a MMU3 what is the best way to by pass MMU3. I'm having issues with my MMU3. I only get about 50% success rate.
When it works I get a pretty good result. But damn it is finicky. The MMU3 turns my work horse into a temperamental cat. Is there a way to by pass the MMU3 and not get error on the screen about not compatible code.
What i do is remove the PTFR tube from hot end and turn off MMU3 in settings. Use prusa slicer settings for mk3.5 and not i3mk3.5 MMU3.
When I load the code, machine it says not compatible code but the code runs fine. Is there a setting I'm missing? I wish that there is a profile in slicr with MMU3 installed but turned off.
Posted : 10/10/2025 6:25 pm
