Elephant Foot compensation is failing
Recently, the Elephant Foot compensation on my MK3.9S has been failing. This happens with PLA and PETG, brands that I have used for a long time, with slicer profiles I have also used for a long time without a problem. The same files and profiles on the Core One do not have a problem. I have tried changing the compensation from 0.2 to 0.3 and 0.4 to no avail. I have tried adding a chamfer to the objects I design, and that helps some, but does not eliminate the problem. Adding a chamfer to STLs can be difficult, if not impossible. The heat bed test passes.
Veröffentlicht : 03/06/2025 3:20 pm
