Mk3 to mk3.9s upgrade y calibration test fail.
Larry Burkett
(@larry-burkett)
Mitglied
I'm looking for some help or guidance as every other calibration test is fine and I don't want to risk printing with the calibration "failing".
When running the xy calibration the x is fine when it goes to the y it goes to the back of the print area and bumps quite a few times then comes to the front bumps once then fails the test. I've tried manualling moving the y axis and it's range is -4 to 211. When I have it come to the front there seems to be a slight issue at 208 to 211 where idk how best to describe it. Maybe a hop or jump of the teeth. But I've tried watching and I don't think it's that. I've tried other solutions such as double checking your bearings, adjusting the tension both higher and looser. Ensuring the tensioners on the y bed frame are properly installed. (Tension screw is facing the back y motor).
Veröffentlicht : 25/12/2024 6:28 pm
majestix508
(@majestix508)
RE: Mk3 to mk3.9s upgrade y calibration test fail.
I have the same issue - y calibration failed.
Veröffentlicht : 05/01/2025 3:26 pm
majestix508
(@majestix508)
This part solved my issue: https://www.printables.com/model/827850-mk4-y-axis-home-calibration-solution
Veröffentlicht : 05/01/2025 3:41 pm
