ASA top Layer issues on a flat surface
BrettG
(@brettg)
Been trying to master the ASA top Layer but still not 100%
from the image what would change to get a better top layer
ASA on the textured plate using 3Dlac adhesive - In an Enclosure preheated and around 30 - 40c when running.
260c Noz - 110c Bed -  Fan 5%
20% infill gyroid and 80% cupid infill just below when it starts to do the top layers
the bottom layer is stuck to the plate without any warping,
I've tried extrusion down to 92% without any luck , played around with fan speeds. added extra top layers, tried the ironing option, tried 2 different brands of filament
all without any better results
Added the Hex pattern to brake up the top layer, the actual part is 6mm thick
Been through the posts on here and reddit without any luck when changing settings to other users
This topic was modified 20 hours ago 2 times by BrettG
Posted : 05/09/2025 9:27 am
