IR filament sensor calibration
organic
(@organic)
I am having a nightmare trying to sensor calibration.
I have only just done my Mk3s to Mk3.5 and MMu2 to MMU3.
Does the IR filament sensor calibration read 1 all the time when nothing in the gap?
I have done all the help from ( https://help.prusa3d.com/article/ir-filament-sensor-calibration-mmu3-mmu2s_2245 ) but no luck.
Thanks for any help in advance.
Napsal : 13/10/2024 9:55 am
lambert se líbí
organic
(@organic)
Picture of what I mean.
I couldn't find away how to edit post.
A picture and it reads 1 when empty.
Napsal : 14/10/2024 7:11 am
lambert
(@lambert-2)
RE: IR filament sensor calibration
Hello, I had the same problem after installing my mmu3. Very inconsistent behavior.
Now I found my problem.
Had to disassamble my  "Step 27 Extruder-idler disassembly" from here https://help.prusa3d.com/guide/9b-mk3s-mk3-5-extruder-mod-kit_420370.
The shaft was dislocated! So the gear was misspossisioned.
Hope this will help you!
Greetings
Lambert
Napsal : 29/10/2024 12:30 pm
organic
(@organic)
Thanks for the help.
I have done that and still not working.
A person from Prusa did start to help me by sending a new cable adapter + IR sensor + cable. Fitted but still same and has stopped with the emails.
The IR sensor is inverted and I am going to try to reflash it again and see what happens.
Napsal : 29/10/2024 1:50 pm
lambert
(@lambert-2)
sorry for that.
Mine worked for about 2 month. Than the problems startet.
I was able to see the ir-sensor turned on when the filament was loaded, and the turned off. This caused the problem.
Then I disassabled the sensor and his arm and dedected that the pin wasnt in the right place. I put it back and this worked well since than. For about a month or so.
So all the best for your troubleshooting
Greetings
Lambert
Napsal : 31/10/2024 10:18 am
lambert
(@lambert-2)
Ahh - now I saw you attached pic. Quite sure your sensor is demaged. - all the best! 👍 Since this worked at my printer this must be your problem!
Napsal : 31/10/2024 10:20 am
MMHN
 MMHN
(@mmhn)
Napsal : 21/12/2024 3:43 pm
