MK4 printable printer parts on MK3 series.
Robin_13
(@robin_13)
I am about to print parts for my printer in ASA as I am going to be  using higher temp materials more often.  I was just making my list and thought that there may be parts from the MK4 that can be used on my MK3.5s+.  Or some of the upgrade path parts instead of the original parts.
Napsal : 22/02/2025 7:37 pm
htfan
(@htfan)
RE: MK4 printable printer parts on MK3 series.
I just completed this upgrade with black prusa petg and I'm very happy with the results. Upgraded one of my mk3s to Mk3.5s and replaced all the bearings/belts at the same time. In addition, I printed all new mk4 parts (less extruder) adapted to the 8mm mk3s rods found on printables.com.
This thing is now extremely fast and rock solid. I already run the Revo Six rapid change nozzles so I am set for my needs. It was tricky to calibrate/belt tune with the longer x-axis since it's a hybrid mk3s revo/Mk3.5s/mk4.
Next I'll do the same thing to my existing Mk3.5 with MMU3.
Napsal : 06/03/2025 11:18 pm
Robin_13
(@robin_13)
Thank you.  I am not going to upgrade to the MK4.  Cannot justify the costs.  Just want to print with a higher temp material.  As the newer designs have fixed earlier issues, I am asking.   Will look at the MK3.5/4 parts and compare them to the parts I see on Printables.
Napsal : 09/03/2025 9:11 pm
1 lidem se líbí
Antimix
(@antimix)
Hello,
I had also the REVO nozzle on my MK3S that now has been converted to MK3.5S because I wanted to keep the REVO, and so I did not upgrade to the MK3.9 that contains the new Nextruder.
Posted by: @htfan
.....It was tricky to calibrate/belt tune with the longer x-axis since it's a hybrid mk3s revo/Mk3.5s/mk4.
- Why you say that you have a longer X axes and it was tricky to tune ? 🤔  Do you have a custom 3.5 upgrade ?
My X rod was the same, reused from the parts of MK3S , and my REVO is the REVO 'Prusa Version' that just fits and replace the old PRUSA E3D nozzle block.
I just calibrate the belt using this gauge or this one.
Regards
Napsal : 11/04/2025 4:58 pm
htfan
(@htfan)
Posted by: @antimix
Regards
Hello antimix,
Since this thread is about "MK4 printable printer parts on MK3 series", It was tricky because my Mk3.5s self test expected a shorter Mk3s X-axis (I now have the longer Mk4 axis). It kept on failing the X-axis portion of the test. I designed/printed some snap-in 6mm spacers for the 8mm bar and placed at both X-axis extremes. It now passes the Mk3.5s self test consistently.
For the belt tuning, I've been successfully using Prusa's tool ( https://belt.connect.prusa3d.com). However, I had to select Mk4 as my printer in that tool to properly calibrate for the longer X-axis belt.
Both of my Mk3.5s printers with mk4 parts have been consistently performing well.
This post was modified před 1 year by htfan
Napsal : 11/04/2025 8:00 pm
