G-code isn't fully compatible
Dschiri1
(@dschiri1)
Well I upgraded from a i3mk3s to a i3mk3.5s. Then I just upgraded to i3mk3.5s with MMU3.  I have some old i3mk3s gcode (VBS 3d face mask small mag_0.15mm_Silk_PLA_MK3S_1h48m - R2.gcode).  I could run this g-code when it was upgraded to i3mk3.5s.  But now it says "The G-code isn't fully compatible".  I've lost my hard drive that had the model and stl files, so it will be very hard to get it back ie 1,500.00 USD. What do I need to do in order to get it to run on i3mk3.5s with MMU3?
DS
Publié : 01/06/2025 11:54 pm
RE: G-code isn't fully compatible
Of course, first the expected admonitions; have backups etc etc.
But that's too late. What you can try—at your own risk—is to disable the compatibility checks.  On your printer, go to Setting>Hardware>G-code checks and set Printer Model to None. I would also disable the MMU in the LCD menu and directly feed filament to the printer, or I'm sure Bad Things would happen.
Publié : 02/06/2025 11:07 am
tfranks
(@tfranks)
Membre
This previous issue is similar to my issue but mine is that the USB stick that came with the upgrade kit gives me an error that says the Printable on the stick is not compatible with this printer. I had several issues with flashing the printer . The BIOS on the stick that accompanied the kit had the newest BIOS so I used them . I eventually downloaded the BIOS on line and the printer worked but I still have 2 more issues . One that says this print is not compatible with this machine and the other is the printer wont pass the hot end or bed heat test  All that being said I am able to print my own prints I slice on my computer .  Hot end and print bed work fine so far . Same as before the upgrade. Any help on any of these issues would be greatly appreciated.
Publié : 26/07/2025 1:05 pm
GymRBK
(@gymrbk)
Membre
Depends on the model complexity, but sometimes it is possible to "reconstruct" it from gcode.
  1. Open the gcode in Prusa Gcode viewer
  2. menu File->export extruder paths as OBJ
  3. open PrusaSlicer, add created OBJ file
- it is not 100% copy, but better than nothing, I guess.
Publié : 28/02/2026 7:05 pm
