Windows installation fails
Børge Strand-Bergesen
(@borge-strand-bergesen)
Hi guys,
The prusa3d_win_2_2_3.exe does not install well on Win10. Is this a well known problem or something which can be alleviated? When I click on the file my computer says
"This app has been blocked for your protection. An administrator has blocked you from running this app. For more information, contact the administrator...."
I have admin privileges on this computer. I hope you can lend a hand so I can get it up and running.
All the best,
Børge
Opublikowany : 12/03/2019 9:06 pm
3Delight
(@3delight)
Moderator Moderator
Re: Windows installation fails
It works perfectly on my Windows 10, system. It is most likely something that has been changed in your Windows Security settings and is blocking the program for some reason.
Opublikowany : 12/03/2019 9:50 pm
carl.d9
(@carl-d9)
I got the same error. I am an administrator on this PC.
Opublikowany : 12/03/2019 10:02 pm
carl.d9
(@carl-d9)
@3Delight we have two users reporting this error on the same day. How long ago were you successful running that file? Perhaps a recent Windows update has caused a problem? Do you have any other ideas what might cause this? I install software all the time and have never run into this dialog.
Opublikowany : 12/03/2019 10:11 pm
3Delight
(@3delight)
Moderator Moderator
Hmmm, you are right, just tried it and it has blocked it?! It says it is from an unknown publisher... I've just looked at it and there is a problem with the Security Certificate... I will notify Prusa Research...
Opublikowany : 12/03/2019 10:24 pm
carl.d9
(@carl-d9)
Thank you
Opublikowany : 12/03/2019 10:30 pm
3Delight
(@3delight)
Moderator Moderator
Turns out Prusa Research we're already aware and were sorting it out! All being well this should be fixed tomorrow (Wednesday 13th March 2019). I'm afraid till then we'll have to have a little patience, thanks for letting us know about it. 🙂
Opublikowany : 12/03/2019 10:44 pm
carl.d9
(@carl-d9)
Thank you
Opublikowany : 12/03/2019 10:56 pm
3D Print Singapore
(@3d-print-singapore)
I used this youtube video LUA to help solve it.
Opublikowany : 13/03/2019 8:13 am
carl.d9
(@carl-d9)
Without knowing the reason for this failure I'm not comfortable bypassing this security feature. While it is unlikely, it is possible this file actually has been corrupted, for example with a virus. These checks are here for a reason.
Opublikowany : 13/03/2019 11:45 am
Chocki
(@chocki)
At least it's not just me then, I had the same last night.
Opublikowany : 13/03/2019 5:51 pm
