Why can't I write a Private Message? [SOLVED]
RetireeJay
(@retireejay)
Private Messages used to work, but now when I try to create one, it doesn't add the addressee but instead shows the name below the add box with a red X beside the name. I would PM the forum administrator to ask why, but I can't.
Napsal : 22/01/2019 2:58 am
Re: Why can't I write a Private Message?
Perhaps some people have PM disabled or their inbox is full ...
Napsal : 22/01/2019 7:50 am
There is a maximum inbox size as well. If it keeps a copy of your sent messages, you may have hit the limit. Check your message inbox and delete older or unneeded messages.
Napsal : 22/01/2019 8:11 am
Hi Jay,,,
I tried to send you a PM, did it work?
is your PM box anything like this?
I believe the red X is to delete the recipients / addressee entry
Napsal : 22/01/2019 1:00 pm
RetireeJay
(@retireejay)
OK, I guess I was mis-interpreting the information. On the other forum that I use a lot, the valid addressees show up in a different place and they don't have a red X beside them. But that forum is using a very old version of the software. This old dog has to learn the new tricks. 😆
Consider this solved.
Napsal : 22/01/2019 2:16 pm
