Which extruder option
Alphacosmos
(@alphacosmos)
Afternoon All,
I currently have a prusa mk2.5 and plan to upgrade to MMU2.0s. I have printed all the files but im confused. In the manual it tells you to upgrade to the extruder with the IR sensor moved. But in the final images it has it set up without the extruder upgraded. I have seen images of the MMU without the IR sensor moved. Which of the images is corrent. 1 or 2??????? Is there a revision or am i missing something here??
12
Opublikowany : 07/01/2020 11:15 pm
RE: Which extruder option
I believe this is an error in the documentation, the MMU2S is intended to be used with either the Mk2.5S or the Mk3S both of which use the newer Infrared filament sensor,
the first picture is how mine is. with the sensor tower.
the second picture is on the previous extruder with the old filament sensor
Opublikowany : 07/01/2020 11:48 pm
