What would you like to see in the 8-bit firmware?
Seite 6 / 20
RE: What would you like to see in the 8-bit firmware?
@mikolas-zuza
And just as buggy as prior versions. I'd say even more buggy than 3.7 was.
Veröffentlicht : 21/05/2021 5:24 pm
blauzahn
(@blauzahn)
@skipper 3D: "I would like to see an option to have to confirm the sheet profile before each print."
Please no! I do not like yet another "Do you really want to..." click style. This is annoying and especially because of that does not help since over time these tend to be clicked blindly.
Initially, I also forgot 2 or 3 times to change the selected sheet profile. Since then I made it a habit to put the new sheet slightly rotated onto the bed as a reminder. Enough so, that it is really obvious. Only after I changed the profile to the appropriate one I immediately shift the sheet into the correct place. Of course, there are ideas going further like e.g. RFIDs, but such might lead into vendor lock in.
Veröffentlicht : 21/05/2021 5:29 pm
Jakob127
(@jakob127)
I would really love to see to be able to select the material type on the printer directly, without having to slice the thing on the computer.
Veröffentlicht : 21/05/2021 5:41 pm
Mitglied
@blauzahn
Manned - maybe someday, but I am not Elon Musk.
Veröffentlicht : 21/05/2021 6:07 pm
@jackjan
The SD card I/O is failing because an idiot designed the LCD control board. Fix that and all of the SD issues and LCD issues would go away.
Veröffentlicht : 21/05/2021 6:42 pm
@jakob-glieder
Clearly you don't understand what a Slicer does.  If you want to select material at the printer, then slice three files: one in each material and save them to the SD. Then, at the printer, select the correct file for the material you want to use.
Diese r Beitrag wurde geändert Vor 5 years von --
Veröffentlicht : 21/05/2021 6:43 pm
Mitglied
@tim-2
What is wrong with the design?
Veröffentlicht : 21/05/2021 6:46 pm
@tomas-kapler
Rush through level to save 15 seconds, then wait for 3 hours while the part prints. I do not understand this.
Veröffentlicht : 21/05/2021 7:33 pm
Joseph Craig
(@joseph-craig)
I don’t know if it’s a limitation of USB vs SD card but the print the latest upload feature on the Mini is a huge time saver if you have multiple printers. I’d like to be able to insert a SD card into my MK2.5’s and just have it ask if I want to print the latest file uploaded. I can click yes and away it goes. Same as mini
Veröffentlicht : 21/05/2021 7:36 pm
brettvitaz
(@brettvitaz)
Change sheet by gcode so it can be assigned in the slicer.
Like tool switching:
  • S0..S4 = Sheets 1 to 5
  • Sx = Select sheet via UI
Veröffentlicht : 21/05/2021 7:47 pm
@cwbullet
If you were an electronics engineer or even a fair technician I wouldn't have to explain it - it's that obvious. Suffice it to say the circuitry is very badly designed. One example, 20 wires, 15 signals, two basic control paths (LCD/SD), one ground used; another is no thought of controlling impedance for cable interconnect (the Einsy end does).
You don't fire square waves down random wires and not expect them to arrive at the other end unperturbed.
This is what should happen:
Here is what is happening:
It's actually worse because the ribbon cables have no isolation between signals, so there is also crosstalk running loose.
Mitglied
@tim-2
I appreciate the explanation and full understand now.
Veröffentlicht : 21/05/2021 7:52 pm
Mitglied
@tim-2
I have to concur.  I understand the want to shave off 15-30s but it makes sense to have a better leveled printer.
Veröffentlicht : 21/05/2021 8:06 pm
RedDawg
(@reddawg)
@cwbullet
I think it's a problem with sensing the pulses being generated by the knob/shaft encoder. When I am setting the temperature manually for the nozzle or the bed, it almost always "overshoots" and I have to dial back a click or two to get it where I want it. It's not really a problem if you are expecting it, but it is annoying and could be fixed (I think).
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Veröffentlicht : 21/05/2021 9:06 pm
RedDawg
(@reddawg)
@cwbullet
I think it's a problem with sensing/counting the pulses being generated by the knob/shaft encoder. When I am setting the temperature manually for the nozzle or the bed, it almost always "overshoots" and I have to dial back a click or two to get it where I want it. It's not really a problem if you are expecting it, but it is annoying and could be fixed (I think).
Diese r Beitrag wurde geändert Vor 5 years von RedDawg
RedDawg
(@reddawg)
Posted by: @tim-2
@jackjan
Is this the same problem that causes the SD card to not be recognized when I plug it in? This happens on both my MK3s and I frequently have to jiggle or unplug/replug. I'm always afraid it's going to vibrate loose during a print and ruin it, but that hasn't happened.  Yet.
Veröffentlicht : 21/05/2021 10:28 pm
Mitglied
Posted by: @reddawg
@cwbullet
It is almost an echo.
Veröffentlicht : 21/05/2021 10:38 pm
RedDawg
(@reddawg)
Posted by: @cwbullet
Guess they should fix that too.
Veröffentlicht : 21/05/2021 10:51 pm
Mitglied
This may have been said above, Marlin 2 base.
Veröffentlicht : 21/05/2021 10:59 pm
RedDawg
(@reddawg)
Oh, missed that, thought you meant my double post.
Veröffentlicht : 22/05/2021 1:24 am
Seite 6 / 20
