What is the effect of heating device on stringing?
Hello, some people suggested using a heat gun, air blower or touch to remove strings. What does it actually do to the strings? Melt them? Blow them away? Merge them into existing prints?
RE: What is the effect of heating device on stringing?
all of the above?
I am a bit worry that doing so would deform or modify the mechanical property of the prints.
Deformation is usually no problem. I use a heat gun for strings/web removal frequently. The air stream just has to be hot and fast so it removes the strings instantly and the model has no time to heat up and deform.
I heard that temperature change affects the quality of printing. Have you experienced any problems?
