what do people do for the end of roll curl?
toaf
 toaf
(@toaf)
ive seen it with a few filaments. the end has a crazy curl like its wound too tight or too warm when rolled.
Opublikowany : 20/02/2019 8:59 am
rob.l6
(@rob-l6)
Re: what do people do for the end of roll curl?
I pour myself a single malt.
Opublikowany : 20/02/2019 10:28 am
Steve
(@steve-3)
I agree it is annoying. The tight curvature stays with the filament making it more likely to break.
One solution would be to create some spool holders with a large center hub. Transfer your filament to the modified spool after using half of the original roll.
Maybe it is easier to just give up on the last 10% and toss it.
Steve
Opublikowany : 20/02/2019 6:32 pm
toaf
 toaf
(@toaf)
ya, it is just around the last layer or 2 on the rolls when it happens. maybe more filament for my pens
Opublikowany : 20/02/2019 6:44 pm
Nikolai
(@nikolai)
The filament run-out sensor should catch it, if filament breaks 😉
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 20/02/2019 6:47 pm
toaf
 toaf
(@toaf)
it does, but ive gotten some nasty curls that mess with things (a few filaments)
Opublikowany : 20/02/2019 6:50 pm
vintagepc
(@vintagepc)
It should be possible to relax the curl by heating the filament slightly to soften it; you'd have to find a temperature that lets this happen without affecting the dimensions though.
Opublikowany : 20/02/2019 6:54 pm
