Weird Blob Position
muo
 muo
(@muo)
Weird Blob Position
I have a blob build up on top of the HeatBlock and i cant seem to unscrew the heat sink the nozzle is kinds stuck but i think i can just put the hot end back in the extrude body and heat it up and get the nozzle out but any of you have ideas on how to get the heat sink out and maby  even the heat break assuming its stuck too? any idea or have you had a similar problem and you solved?
Publié : 22/01/2020 2:20 am
muo
 muo
(@muo)
RE: Weird Blob Position
just cleaned it looks nice now, ended up using a paper clips to clean it after putting it back in  the extrude body and hating it up there was only cosmetic damage from the paper clip on top, also cleaned the heatBlock and the Heat break after dissembling it, by using pliers to hold heat block and heat break over a stove and cleaning it with a brass brush. looks good so far. Looks like i need to fox the heater cable
Publié : 22/01/2020 11:03 pm
