Using MK3 sheets on an XL (and other under-sized print sheets)
Early in the promotion of the XL it was mentioned that it was compatible with MK3 print sheets. Has anybody tried this? (I haven't). I assume you just arrange your models on a MK3 sized area of the XL bed. Is that all there is to it? What about bed probing the XL does? Does the bed heat controller detect this?
Posted : 25/11/2023 11:47 pm
RE: Using MK3 sheets on an XL (and other under-sized print sheets)
I believe in PrusaSlicer you select Printer Settings > General > Bed Shape and load model from MK3 and use it for slicing?
Posted : 26/11/2023 8:28 am
