Using MK3 sheets on an XL (and other under-sized print sheets)
EvilleBill
(@evillebill)
Early in the promotion of the XL it was mentioned that it was compatible with MK3 print sheets.  Has anybody tried this? (I haven't).  I assume you just arrange your models on a MK3 sized area of the XL bed.  Is that all there is to it?  What about bed probing the XL does?  Does the bed heat controller detect this?
Napsal : 25/11/2023 11:47 pm
_KaszpiR_
(@_kaszpir_)
RE: Using MK3 sheets on an XL (and other under-sized print sheets)
I believe in PrusaSlicer you select Printer Settings > General > Bed Shape and load model from MK3 and use it for slicing?
Napsal : 26/11/2023 8:28 am
