USB memory stick is broken on my laptop, but works on the 3D printer!
Cassolotl
(@cassolotl)
I am having this issue with a USB memory stick, and I am wondering if anyone else has run into it and has been able to salvage it. I don't need the files on the USB stick, I just don't want to have to throw it away!
It happened without warning and I'm not sure that I did anything that prompted it. It was working one minute, and the next it was broken.
When I plug the USB stick into my laptop (Mac Tahoe 26.3.1), it seems to mount okay, but the Finder window shows endless loading swirlies where the files would be listed. When I click "eject" it doesn't un-mount. In Disk Utility, the drive shows up, but attempting to erase, reformat or repair it results in a failure message, and the explanation is that it couldn't unmount the drive.
This happens on two different laptops, both Macs. It also happens in Disk Utility in recovery mode. I have restarted my laptop, I have force-quit Finder, and I have tried using Terminal instead of Disk Utility - all have the same outcome.
However, when I plug the USB stick into my 3D printer, the .bgcode files show normally.
Has this happened to you? Were you able to fix it?
Postato : 25/03/2026 12:59 pm
Memory sticks are consumable items. Just get another one. Or use a Micro-SD with an adapter.
Postato : 25/03/2026 1:34 pm
Cassolotl
(@cassolotl)
RE: USB memory stick is broken on my laptop, but works on the 3D printer!
Posted by: @hyiger
If you aren't answering the question you can simply not reply!
Postato : 25/03/2026 2:10 pm
Posted by: @cassolotl
Posted by: @hyiger
So you have a bad memory stick and you are asking us how to fix it? My solution still stands... get another one...
Postato : 25/03/2026 2:24 pm
Kachidoki
(@kachidoki)
Yes. No.
Then keep it in a drawer or make a neckless with it.
Answered?
Seriously, it looks like a bad memory stick. Even if I could recover it, I'll never trust it again. You'll quickly loose more filament on failed prints than the price of a new stick.
Postato : 25/03/2026 3:16 pm
shrap
(@shrap-2)
Last ditch effort if you tried to use it on 2 macs would be to see if you can format it on a Windows PC.
If that doesn't work, yea you got yourself a new paper weight. Just my 2 cents.
Vehemently against AI. I've seen that film. It ends badly.
Postato : 25/03/2026 3:35 pm
1 persone hanno apprezzato
Cassolotl
(@cassolotl)
Posted by: @kachidoki
Yes. No.
There's no need to be weird, I just wanted to check whether there was a way to repair it.
Ahhh, that is a shame. Thanks anyway.
Questo post è stato modificato 2 months fa da Cassolotl
Postato : 25/03/2026 3:55 pm
JimB
 JimB
(@jimb)
A possible reason why the printer seems to see the files is that it has probably only looked at the top-level directory and just read the file names.  However your computer is probably trying to access more information about and from the files.  So some parts might still be readable, but others not.  It is highly unlikely that the printer could print any of those files anymore.
I agree with the others: it's dead.  But it'll be rewarded for its service in Silicon Heaven.
Postato : 25/03/2026 5:38 pm
Cassolotl
(@cassolotl)
Posted by: @jimb
It's showing me a preview image, print times, etc. as well, but yeah, that doesn't say much about whether it'll actually print!
RIP, USB. :'(
Postato : 25/03/2026 5:55 pm
Conrad
(@conrad-2)
I'd never trust it again, but you could try doing a FAT32 format with a 3rd party utility in Windows. I have to do that because FAT32 is all the printers will understand.
Postato : 25/03/2026 6:15 pm
