Tuning PID
alex.c3
(@alex-c3)
Tuning PID
Hello all!
I've been having issues with my printer holding temperature (I'll tell it to print at 220C/55 and it'll print at 214/55, and continue to go down from there) I wanted to tune the PID settings through Pronterface. I plugged in the printer with the supplied USB cable, into a USB 2.0 Port, opened up Pronterface, hit the "Connect" button, and then nothing happened. It keeps showing "Connecting..." and nothing ever changes. I'm not sure why this is happening or what I can do. This temperature issue has been quite annoying as I can't print a few filaments I just bought because the temperature keeps dropping. Is there some way of fixing this issue?
Sorry to bother you and thank you!
Issue above has been solved.
New question: Since my printer has difficulty holding temp above 215, how would you suggest I start tweaking?
Respondido : 23/12/2016 10:50 pm
alex.c3
(@alex-c3)
Re: Tuning PID
I also tried changing the USB port, I kept getting this error:
[ERROR] Could not connect to COM3 at baudrate 115200:
Serial error: could not open port COM3: [Error 5] Access is denied.
Edit:
Just had to restart the computer, never mind
Respondido : 23/12/2016 11:37 pm
simon.p
(@simon-p)
Re: Tuning PID
New question: Since my printer has difficulty holding temp above 215, how would you suggest I start tweaking?[/b]
Your forum search skills or mention that you have searched all relevant posts but didn#t find any inspiration to your problem.
Respondido : 24/12/2016 11:39 am
bcheck555
(@bcheck555)
Re: Tuning PID
Search is going to be the best help, but basically, you can:
make sure you have the set screw in the heater block for the thermistor ( http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/thermistor-screw-t2635.html )
increase power supply voltage
modify PID settings (does not work on firmware v3.0.9 https://github.com/prusa3d/Prusa-Firmware/issues/18
I still get thermal errors with bridging PETG, but I am getting closer to the best settings.
Respondido : 24/12/2016 6:08 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Tuning PID
Actually it does work and the effects can be seen in the OctoPrint temperature graphs.
Peter
Respondido : 24/12/2016 11:51 pm
bcheck555
(@bcheck555)
Re: Tuning PID
Peter
Perhaps you could post to that link and maybe help us figure out what we are doing wrong.
Respondido : 02/01/2017 2:17 am
PJR
 PJR
(@pjr)
Re: Tuning PID
Brian
I am printing right now, but please accept that this is the graph after setting the PID in GCode:
Note that I am using a sock and without the PID settings, the temps vary rapidly by +- 5 degrees.
Peter
Respondido : 03/01/2017 7:08 am
