TPU print stringing
gingerman
(@gingerman)
TPU print stringing
I'm using "Ooznest TPU Bend", it's ok if you print only one object on the bed.
If you run it at 15mm/s it does not jump out the side - in fact it will run faster than that - but don't be greedy.
I use their suggested profile. I do not use retract. Z hop is on. I have an enclosure, but I leave the door open - it does not seem to matter. The bed is 50-60ºC and the nozzle 240ºC.
Stringing is a real pain. So this means that if you print multiple objects or objects with large voids - you will have a hell of a clean up job.
Vase mode prints perfectly as the head never lifts off.
Also support material is hard to remove - but often pulls off without scarring,  despite having to man handle it.
Sometimes it is a real pain to remove.
I often print pods for quads/racing drones and I smooth them with a heat gun which can look sweet - but it's really easy to overdo.
This pod is printing atm - it's really hard to photograph but the texture is lovely.
The only issue is the stringing ( and the globby stuff on this print due to the head having to travel through a no printing part ).
I'd love to get rid of the stringing. ( This looks 5x better in real life - the texture is sweet ).
Postato : 03/05/2019 8:01 am
gingerman
(@gingerman)
RE: TPU print stringing
Here is a before and after pic of the stringing - the after pic is not as good - it looks really good in real life. It only needs to be functional.
Postato : 03/05/2019 9:18 am
violetevergarden7511
(@violetevergarden7511)
omg! this looks so neat and crafty.
Postato : 04/05/2019 5:54 pm
Sidbitters
(@sidbitters)
In the file section in the Prusa Community on facebook there is a tpu file I have used called pp something and there was no stringing on pieces I made.
Postato : 07/05/2019 4:36 am
vintagepc
(@vintagepc)
Utenti
Dry your TPU. Stringing gets worse as it absorbs more moisture.
Postato : 07/05/2019 11:39 am
