RE: Tools: What do you recommend?
I use long needle nosed pliers to get the filament before it does the bed levelling and purge. I am however going to either print or buy a plastic set as the metal ones can set off the pinda probe if I get too excited. I did get a set of rather nice set of fine brushes for cleaning nozzles with a batch of cheepo nozzles I for for my Anet A8 a few years back. the printer and nozzles were donated to the face shield cause but I still have the brushes.
The tool I would like however, but cannot find at present, is a soft brass brush to clean the nozzle/hotend of goop. I thought it would be as simple as getting an old fashioned suede brush but these all appear to be plastic now......damn this age thing.
Andrew
@andrewld
Are you thinking of brass brushes like these? https://www.wire-brush.co.uk/wirebrushstore/cat_283882-Brass-Hand-Wire-Brushes.html available on amazon /ebay etc.
@gordon-w
I have to agree brass brushes are essential.
In the US, I have found a good price at Harbor Freight: Brass Brushes
and
Amazon:Brass Brushes
@gordon-w
No those are too fierce for my liking. I used to have wooden handled ones about the size of a toothbrush that had soft wire bristles for taking the mud off my desert boots.
Andrew
@charles-h13
Nice. I didn't see these on amazon UK. Will have another look.
Andrew
@andrewld
I will try to post UK links also in the future, It can be tough to find them.
@charles-h13
I created my own nozzletool set:
The PEEK (CarbonPEEK) insert is heat-resistant up to 260 degrees C. The torque ratchet can be adjusted. Ideal in tight spaces.
@karl-herbert
I like that. I have never printed peek. Did you print that on a Prusa?
While I'm at it. I also use this tool very often (Extruder, MMU2, others) to cut and chamfer PTFE's:
@charles-h13
Yes, printed it on a mod. MK3 (Pt100 upgrade up to 500 degrees C. , bedboost up to 150 degrees C.).
The fanshroud was also printed with the extrem heatresistant CarbonPEEK ( https://www.filamentworld.de/shop/high-performance-filament/peek-filament/3dxtech-carbonx-1-75-mm-carbon-peek/ ) or ( https://www.3dxtech.com/carbon-fiber-filaments/carbonx-peek-cf/ )
Someone in the forum also recommended the tungsten carbide electrodes, which I now use and really appreciate:
https://www.amazon.de/gp/product/B07R6Y2LKS/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
@karl-herbert
That would be me!
Did you share the cutting and chamfer tools online?
@charles-h13
Thanks again for the tungsten c. link!
Chamfertool - yes, look here (description in German): https://www.prusaprinters.org/prints/34035-ptfe-multitool
Beware of cheap brass nozzle which are brass plated steel, you can check with a magnet, they can damage brass nozzle hole if used with vivacity. No problem with hardened steel nozzle of course.
MK3S & Fusion 360
@flo-r
I cannot recommend cheap nozzles because high quality nozzles are an important part of successful printing. That's exactly where I don't save my money. And if you use them correctly, you will enjoy them for a long time.
Ho sorry reading me back I wrote a mistake I wanted to write beware of cheap brass Brushes they can damage brass nozzle because the are brass plated steel.
By the way I clearly do agree with you about high quality nozzle.
MK3S & Fusion 360
@flo-r
No need to apologise. I agree on the cheep nozzles. I'm not saying there aren't good less expensive ones but for now my prints have been so good I wouldn't want to upset the lady by getting her anything Joseph hadn't. 🤣
@karl-herbert
I agree to a point. I think cheap nozzles are hit and miss. You have to choose wisely
@charles-h13
