test 11 out
Laurent
(@laurent-5)
Utenti
test 11 out
Bonjour les Makers
Titine a presque passer tous les tests Mais elle a callé au 11ème
capteur bien cablé ,donc a voir
Postato : 20/01/2026 9:58 pm
RE: test 11 out
You probably posted in the wrong forum section by accident. I see that you already have a few posts in the French Core One forum. That's where this post should go; with the context there you can probably get better responses.
The filament sensor calibration checks both sensors -- the one in the Nextruder and the one on the right side panel. Can you tell which sensor is causing a problem?
Postato : 21/01/2026 7:12 am
