Temperature management in enclosure
Lockdown
(@lockdown)
I have made an enclosure for my mk3 so I can print ASA etc better.  I am concerned the stepper drivers will get to hot so I have a 4pin 40mm fan that ducts outside air onto the stepper drivers.  What temperature should I be aiming at keeping the board at?
Likewise, is there an ideal temperature for the enclosure or is it just the hotter the better for the prints?
Thanks.
Napsal : 12/01/2025 10:56 am
RE: Temperature management in enclosure
I've never seen any issues with stepper drivers, and I'm not venting air.
Napsal : 13/01/2025 1:57 pm
Lockdown
(@lockdown)
They move the PSU outside because the extra heat is not good for it and I had heard the Einsy board and the drivers like being kept cool as well.  I have set mine up to have a gentle flow of cool air into the Big Einy Case I printed.  I am still not sure about the best temperature but it is way cooler than the enclosure so it is a big plus.
Posted by: @foxrun3d
Napsal : 16/01/2025 6:25 am
_KaszpiR_
(@_kaszpir_)
Afair specs for the motors state they can operate in ambient temperature to about 90C.
If you have PETG parts then those would rather be in danger, not the motors 🙂
Napsal : 16/01/2025 8:59 am
1 lidem se líbí
Lockdown
(@lockdown)
I am not concerned about the stepper motors themselves.  It is the electronics and particularly the motor drivers that concerns me.
Napsal : 16/01/2025 5:19 pm
Robin_13
(@robin_13)
Enclosure temperature is more of a factor for the filament.  PLA, you need it cool.  Some you want it hot to help with warping.  On my MK3s I added some heatsinks to the Einsy board on the drivers as recommended by others.  I have had my enclosure to 50 degrees with no issues.
In my workshop, during summer it can get to >35 degrees if I have doors open.  As _KaszpiR_ says, the PETG parts would most likely fail before the electronics.
There are some threads on how to move the Einsy board out of the enclosure.
Napsal : 20/01/2025 9:31 am
1 lidem se líbí
Lockdown
(@lockdown)
Posted by: @robin_13
Thanks for the info on PLA.  I hadn't considers it but I am now creating a profile to cool the home enclosure for PLA.  👍
Napsal : 26/01/2025 12:02 pm
