Stepper motor vibration problem
Hi everyone, I am trying to dampen the vibration of the stepper motor on the x-axis of my plasma cutting gantry, the stepper causes vibrations when the motor moves and the vibrations are transferred to the entire floating head including the torch head... I currently have a damper between the motor and the x-axis which dampens the sound but still physically vibrates, I am using a rack and pinion with bearings all around the square tube and a nema 23 stepper motor ( https://www.oyostepper.es/category-7-b0-Motor-paso-a-paso-NEMA-23.html ).
Can anyone give me some ideas on how to get it to run as smoothly as possible as this will affect the quality of the cut of the part.
Thanks
RE: Stepper motor vibration problem
This site is for support of Original Prusa 3D Printers, you are better off looking on Reddit for help.
