Slicer adding unwanted top infill?
thesillyrabbit
(@thesillyrabbit)
This is the first time I have designed and printed something from scratch so bare with me.
In google sketchup, I made this simple box for film rolls. Export stl, import into Slicer. When it imports it looks fine at first but once I slice it is covering up half of my box with an infill. Is there a setting I have selected? anybody see this before?
In fact, if I toggle back and fort the preview looks fine, the sliced have the infill.
This topic was modified 7 years temu 3 times by thesillyrabbit
Opublikowany : 21/06/2019 8:33 pm
RE: Slicer adding unwanted top infill?
My initial guess is you have multiple shells, and the infill you see is actually the top of one of the closed shells.
Opublikowany : 21/06/2019 11:52 pm
Peter M
(@peter-m)
Walls to thin? try detect thin walls in the settings.
I do not if this is possible, use a blocker to block infill.
Check if you do not have more then 1 stl in the slicer, on the wright screen, you can see if the slicer sees more then 1 stl.
Do other slicer programs do the same, always useful if want to know if it is the slicer or stl.
This post was modified 7 years temu by Peter M
Opublikowany : 22/06/2019 5:43 am
