Slic3r PE Slicing problem
michael.c31
(@michael-c31)
hello
i am trying to figure out what I can to to get an STL to slice correctly. the STL when viewed in 3d looks fine but after slicing in the preview tab there are missing parts. the attached photo show the issue.
Napsal : 13/05/2018 1:24 am
Rosparovac
(@rosparovac)
Re: Slic3r PE Slicing problem
Problem is not in slicer but in model. I have this problem with some downloaded model and use https://www.trinckle.com/en/printorder.php to repair it. Or if you are familiarized with blender, you can use it.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Napsal : 13/05/2018 8:50 pm
tobydanger
(@tobydanger)
The latest 1.39.2 Slic3r PE from the 2.1.5 driver pack has some problems, IMO. If you are using this, I'd downgrade back to 1.39.1 or try the 1.40.0-alpha. You can try to repair the file using Windows 10 3d Builder, service.netfabb.com, or makeprintable.com. If Slic3r doesn't say the file has errors in the lower right, there's nothing to repair.
Napsal : 15/05/2018 6:33 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
The newest Slic3r-1.40.0-alpha1 should handle these models much better. Please note it is an alpha, use with caution.
https://github.com/prusa3d/Slic3r/releases/tag/untagged-8fc8ca127d0924fe5504
Napsal : 15/05/2018 7:37 am
Kai
 Kai
(@kai-2)
You can also repair files like that easily with the Microsoft 3d builder.
That works very well (for me).
nec aspera terrent
Napsal : 18/07/2018 3:22 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
The current Slic3r PE has the option to call the NetFabb repair service. This is the same service that the Microsoft 3D Builder is calling, so you should get exactly the same results.
Napsal : 18/07/2018 3:31 pm
Kai
 Kai
(@kai-2)
Perfekt, thanks for the Info.
nec aspera terrent
Napsal : 19/07/2018 8:47 am
