sd card not reading all the time
ggeh
 ggeh
(@ggeh)
sd card not reading all the time and some times during a print it looses connection. Is there away to clean the contacts in the LCD unit?
Thanks Gary
Veröffentlicht : 15/04/2021 3:08 pm
muddymaker
(@muddymaker)
RE: sd card not reading all the time
A quick and easy fix is to clean the contacts of the SD card with a small pencil eraser and voila bob's your aunty. If have electrical contact cleaner that works well in conjunction with the eraser.
Veröffentlicht : 16/04/2021 11:47 pm
ggeh
 ggeh
(@ggeh)
@muddymaker
Thanks for the quick response.  I cleaned all my SD card contacts as you suggested before I made the post. I beleave the problem is in the SD card holder that's on the pc board. Not sure if its dirty loose or just wore out. I don't know if there is a way to clean the contacts  in the card holder. I can wiggle the SD card sometimes to get it to read but I did have a 6-hr print quit about half way through  just from the vibration of the printer causing it to loose contact.
Thanks Gary
Veröffentlicht : 17/04/2021 3:57 pm
gconover
(@gconover)
I was wondering if you can use a 2nd sd card to add projects while the other is in the printer.
Veröffentlicht : 17/04/2021 4:39 pm
ggeh
 ggeh
(@ggeh)
"I was wondering if you can use a 2nd sd card to add projects while the other is in the printer."
Yes, but what has that have to do with the problem Im having?
Veröffentlicht : 17/04/2021 7:37 pm
