Screw Terminal
mohammed.hossain
(@mohammed-hossain)
Screw Terminal
Hi all,
What's the size of the screw terminal in einsys board for the leads in the bed heater? The positive lead from the bed burned on my end and I need to replace  it. :'(
Looking to replace the screw terminal pictured below.
Publié : 15/02/2020 2:08 am
vopima2188
(@vopima2188)
RE: Screw Terminal
Posted by: @mohammed-hossain
Hi all,
Hi buddy, even am finding the same for replacement, did you select any yet as of now?
Regards,
V. Smith
Publié : 22/02/2020 8:11 am
nilok
(@nilok)
RE: Screw Terminal
Are either of you close to a Home Depot or anywhere with a screw selection?  It may be easier to match the thread pitch and cut something if you're in a pinch.  No worries about material quality or shoddy coatings with Amazon orders either.
I cant measure because I'm in the middle of a 8hr print....but maybe this link will help.  I'd guess the Rambo board just has a standard terminal block attached.
https://www.wiringdepot.com/jt-t-tech-articles/What-does-Stud-Size-mean
Is your printer grinding? Bearings squeaking? Motors smoking?
Step 1) Wash your Steel Sheet
Step 2) Return to Step 1
Publié : 24/02/2020 1:01 am
mohammed.hossain
(@mohammed-hossain)
RE: Screw Terminal
Unfortunately, (and apparently) terminal screws are really difficult to get your hands on in New York City and yeah I have been to where-ever you would normally expect to find terminal screws but didn't find any.
And that's exactly what I ended up doing... cleaned the screw.
Publié : 01/03/2020 12:20 am
RE: Screw Terminal
They are most likely 6-32... and I found a drawing of similar parts:
https://www.molex.com/pdm_docs/sd/387006102_sd.pdf
Publié : 01/03/2020 4:01 am
vopima2188
(@vopima2188)
RE: Screw Terminal
Posted by: @vopima2188
Hi all,
Regards,
V. Smith
Hi buddy, any update on this yet?
Regards,
V. Smith
Publié : 15/04/2020 11:05 pm
