Review - Reusable Vacuum Seal bags with Hand Pump.
Clarmrrsn
(@clarmrrsn)
I recently took a punt on a set of reusable Vacuum seal bags from Amazon, reason being, I was finding a lot of filament did not come with a resealable bag, and this was doing my head in.
So I looked for a reusable solution that meant I did not have to keep throwing plastic in the bin and helps the enviroment a little in our rather environmentally unfriendly hobby.
I found these on Amazon, and even although the reviews were limited, I decided to give them a go.
https://www.amazon.co.uk/dp/B08YNH8Z9G/ref=cm_sw_r_cp_apa_glt_fabc_4JW2NMVHQVKTZQ5GP0SF
You get a pack of 10 bags, 2 seal clips and a hand pump.
Stick the filament in the bag with a dessicant pouch, run the seal clip along to seal correctly, you can also buy humidity cards to put inside if you wish, but I did not bother.
First attempt had me confused, could not get the air to vacuum out, however there is a knack to this, you need to have the port flat on a desk, or with chunkier rolls I put something under to support the port to keep it flat, then apply firm but not too hard downward pressure, keep pumping and just slightly adjust angle and pressure until the air starts to remove.
BEFORE
Then give the port a flatten with your finger and bingo, vacuum sealed filament, takes around 30 seconds.
AFTER
This roll of Sunlu marble PLA was sealed well over a week ago, and has held pressure perfectly.
I really was not sure due to some bad reviews for similar products, but they work very well, give them a go. 👍
Tank you very much!
Veröffentlicht : 21/04/2021 8:00 am
Tracy und jsw gefällt das
jsw
 jsw
(@jsw)
RE: Review - Reusable Vacuum Seal bags with Hand Pump.
Looks almost like the factory-packed spools.
Veröffentlicht : 21/04/2021 9:33 am
Mitglied
I have had similar results from SOVOL Vacuum Bags.  I posted a review on my site.
Veröffentlicht : 21/04/2021 11:09 am
Clarmrrsn
(@clarmrrsn)
@cwbullet
Was not expecting much TBH Chuck, but they have been very impressive so far.
Not sure how long the valves will last, bit too early to tell, have you had any begin to leak after heavy use?
Tank you very much!
Veröffentlicht : 21/04/2021 12:42 pm
I got a generic set off AliExpress. It's got a snub pump and I couldn't get it to evacuate air. The pouches are just a tad too small to use comfortably. The "seal" is just a sticky patch over a hole on these.  I'm glad to see there is a set that works. Meanwhile, I'm using the 10 bags as just regular resealable bags.
Veröffentlicht : 21/04/2021 2:29 pm
Mitglied
@clarmrrsn
I own several brands and will review each over the next month and post it to my site.  I am very happy with most and only one have one bag that has leaked.
Veröffentlicht : 21/04/2021 2:47 pm
AndrewTerry gefällt das
Update: I gave it another try based on  @Clarmrrsn's description and it worked. Thought I'd tried everything, but I guess I didn't have the bags flat enough before. Now this cheap set seems to be working. I'll keep an eye on it over a few weeks. That seal seems flimsy, but happy to be wrong. Sure takes a lot of pumping. It would be nice to have a larger pump. Thanks for the motivation to check this again.
Veröffentlicht : 21/04/2021 2:48 pm
3DPO
 3DPO
(@3dpo)
Hi, i got a similar set from E3D. They seal great, but i put the large dessicant pack that comes with a new spool of filament in against the side of the filament and Not in the centre just in case it ended up in its own sealed section isolated by the reel centre section.
If its not broken, leave it alone. Less is more.
Veröffentlicht : 21/04/2021 4:28 pm
egar
 egar
(@egar)
I'm not sure where I saw this, but I had a bookmark for this vacuum system with a battery powered vacuum pump.  It got a good review wherever it was that I saw it.  Price and quality seem reasonable.  This is a link for the whole bundle, but bags and pump can also be bought separately.
https://www.printedsolid.com/products/nanovac-vacuum-pump-airlock-bag-bundle
Veröffentlicht : 21/04/2021 4:30 pm
Mitglied
@stephenorchid65
Nanovac is probably the best.  I also like Vacbird pumps and baggies.
Veröffentlicht : 14/07/2021 11:00 am
