Reuse Silca gel to filament 🙂
Olafejs
(@olafejs)
Does anyone else do it like me? or have better way ?
Napsal : 08/08/2022 4:42 pm
RE: Reuse Silca gel to filament 🙂
I just throw my reusable packets into the dryer with my filament spools. Nothing special.
Napsal : 08/08/2022 5:35 pm
I use renewable mini dehumidifiers instead.
Napsal : 08/08/2022 5:56 pm
1 lidem se líbí
JustMe3D
(@justme3d)
I have a re-usable Silica pack in each spool´s ziplock bag, works for me perfectly in German climate. I dry the packs once a year in the oven, getting them down from about 12g to the original 10g weight. I only have about a dozen filament spools in use at any time and some spools have survived for three years. I print in an enclosure which gets warm and thus probably does not add any humidity to the filament whilst in use. Never had any problems with wet filament.
Cheers
Chris
Napsal : 08/08/2022 6:07 pm
Thomas Lynch
(@thomas-lynch)
I bought some bulk silica gel (7.5 lbs) and some small cotton bags with draw strings. I fill each bag about 3/4 full and place 3 to 4 bags in each of the sealed plastic containers  I have for my filament. I put a humid sensor on each of the containers and keep track of the humidity in each container. When it gets close to 30% I gather up the bags and empty them into a paper plate and dry them in my microwave. It only takes about 2-3 minutes to dry them. The silica gel is dry when the color returns to orange. Then I refill the bags and put them back in the containers This lasts for quite a while. Each container is about 30 cm x 30 cm x 45 cm. One is a little bigger. Each container holds about 9-10 rolls of filament.
Napsal : 09/08/2022 1:40 pm
SailorEric
(@sailoreric)
Printed containers that fit in the spool centers. In my dripping wet climate I pour out the silica into a microwave dish and run on 50% power for 3 minutes, stir it around them three more. The color change indicators show it lasts two weeks or so of use in the filament dryer.
Napsal : 11/08/2022 12:19 pm
Artur5
(@artur5)
I use a similar system. Only special thing is that my 3D printed containers are made from PC blend, so they can withstand the maximal temperature reached inside my PrintDry filament drier.
Napsal : 12/08/2022 6:43 am
