Reinforcing around holes
zoookii
(@zoookii)
Hi Guys,
Just took delivery of my new Mk3 and have started drawing and printed.
I designed a bracket that has bolt through it to clamp on to something, the problem I have is that there isn't enough material around the bolt hole and crushes easily when you do the bolt up. Other than printed the whole thing solid is there a way to reinforce certain parts of the bracket?
Many thanks
Russ
Veröffentlicht : 21/09/2019 8:39 pm
RE: Reinforcing around holes
Use MODIFIERS in the slicer to add perimeters to key areas that need more strength.
https://blog.prusaprinters.org/model-with-prusaslicer-modifier-meshes-tutorial/
Diese r Beitrag wurde geändert Vor 7 years von --
Veröffentlicht : 21/09/2019 8:50 pm
Peter M
(@peter-m)
Adjust slicer with more perimeters.
2 is standard, make this 4 or 6.
More infill will also help, max is 40 or 50%
Use different filament.
Use MODIFIERS to fill in to 100%, there where you need it.
Veröffentlicht : 22/09/2019 6:51 am
