Prusament PLA Perl Red
Martin
(@martin-10)
Hi Guys
Has anyone had any issue printing the PLA Perl Red.
Over the year or so I've had the printer, I've had very few failed prints, just occasionally.  Having loaded a new roll of Perl Red, almost 100% failure.  I usually print an outline brim, a couple of mm away, to get things stable, generally this fails to stick, either at the very beginning or someway around the outline and gets tangled up.  I think it's safe to conclude it's the filament ...  Oh, bed temp is 60 degrees, hotend 215.
I've tried re-running first layer calibration - this eventually works, about -0.95mm. - just a bit lower than I had it previously (that was -0.8 ish) - I've cleaned the bed (isopropyl alcohol / acetone) - no luck at all.  I then had the bright idea to switch back to the previous roll of Prusament silver PLA, I had a bit left - without changing anything it worked, no issue.
Thanks in advance,
Martin
Veröffentlicht : 03/05/2020 8:16 pm
Martin
(@martin-10)
RE: Prusament PLA Perl Red
Veröffentlicht : 03/05/2020 8:18 pm
Dave J
(@dave-j)
Try increasing the bed temperature,  take it up by 5 degC to see if it starts to stick better. I usually find that different colours within the same type and manufacture often require different settings. Unsurprisingly, silver is a very easy colour to work with, I wonder if this is the reason Prusa supply it with their new machines. I find yellow is one of the most difficult to work with.
Cheers,Dave Jackson"Enthralled Nooby (not so much maybe, ~58 years old)... If 3d printers had been around 40 years ago... "
Veröffentlicht : 04/05/2020 3:10 pm
Martin
(@martin-10)
@david-j21
Thank you - yes, silver prints dead easy, and that was what I was using previously.  I'd also used a few rows of Comcast (from Amazon) in this and my other frontier with no issues, so I guess I got a bit complacent.  I just upped the bed temp to 65 and slowed the first layer down to 35% (was 40% before, and so far so good.
Thank you for taking the time to reply,
Kindest regards,
Martin
Veröffentlicht : 04/05/2020 8:37 pm
