Prusa Slicer
I have a mysterious box, it looks like a printable object, showing up in the slicer when I insert an STL, while it disappears after the slice this is not a part of the STL and it cannot be deleted. Any ideas?
RE: Prusa Slicer
Without a photo or--ideally--a .3mf project file it's guess work but it could be a) a divine sign that a treasure chest is coming your way in the future or b) much more likely, you have the wipe tower turned on in Print Settings/Multiple Extruders.
Best way to get quality advice here is to save your project from PRusaslicer's Save menu as a .3mf file, zip it. And upload it here. You have to zip it or the forum software will not accept it. This way we can see all your settings.
RE: Prusa Slicer
I will get on that and post, thank you for the direction.
RE: Prusa Slicer
I'm going to guess that you have a printer capable of multimaterial configured and its the wipe tower. If enabled it needs a block to print the material to so its added to the plate automatically to show you where the purge block will be printed.
RE: Prusa Slicer
I saw that in a model I sliced yesterday (the Mini+ LCD back panel). I think it is for defining a different fill in that region. Mystery translucent box around part of the model that disappears in the sliced view.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
RE: Prusa Slicer
Unlikely though. The OP said it can't be deleted. You can select and delete modifier meshes.
