Prusa Printer Paradox
Atem
 Atem
(@atem)
I have three printers of the Prusa i3 mks+ variety, I want to use a micro:bit to connect my Macbook to the Prusaslicer so that I can print wirelessly, is there any way that I could do that? And if so, how?
Thanks in advance!Microbit GO in box just sitting there This is the micro:bit I have.
Napsal : 09/09/2024 5:54 pm
Please explain more - PrusaSlicer already runs on MacOS and Microbit wireless comms are extremely limited.
Napsal : 09/09/2024 10:13 pm
_KaszpiR_
(@_kaszpir_)
RE: Prusa Printer Paradox
Micro:bit itself has only Bluetooth on it and AFAIR Bluetooth TCP/IP stack be problematic.
If you want to use wifi it would require something like IoT:bit ( which uses ESP8266 or ESP32).
All in all raspberry pi zero would be just cheaper and easier to do and is supported already.Micro:bit would require some development and  probably some coding of the modules in lower level than their default stack (unless someone already did it).
All in all Raspberry Pi Zero W would be just cheaper and easier to do and is supported already.
Napsal : 10/09/2024 5:42 am
