Prusa Badges and Rewards... What you want to know!
Seite 18 / 19
OK, while the simplest would be to delete everything uploaded since mid December 2021, scrapping the whole rewards system and dropping Prusameters it might help a bit to silently delete anything with no pictures of an actual print and anything with 0 second party downloads after a week and insist on a comprehensive, editable wiki-style, search declaration.  We also need some sensible quality control - perhaps an automatic email offering a meaningful chance to rate long term such as: "You downloaded X one year ago - did you print it?  did it work? have you reprinted it? were the print and build instructions adequate? do you still use it?"
Veröffentlicht : 21/03/2025 5:40 am
Peter H
(@peter-h)
RE: Prusa Badges and Rewards... What you want to know!
Zero second party downloads after a week would eliminate some really useful prints.
For instance: ten downloads per year for four years does not mean that someone has not found this model useful.     (By the way, I printed and uploaded the original after designing it despite your insistence that models should be tested for a year...) Four years later I can confirm I've used it again to replace the second OEM one which broke.
A user rating after a time would be cool,  and I agree that if it hasn't been printed it shouldn't be there.
Have you made these suggestions to the Printables team, or do you just roll them out here from time to time?
Cheers,
P
Veröffentlicht : 21/03/2025 7:01 am
Netpackrat
(@netpackrat)
Posted by: @peter-h
Cheers,
P
What he said, and not only would it eliminate a lot of useful prints, it would discourage people from posting many others.  Case in point:
https://www.printables.com/model/1042362-gridfinity-holder-for-criterion-tenth-setting-bori
I fully expected to see zero downloads of this Gridfinity holder which I made for a fairly rare machining accessory that I own.  If they had a system in place that punishes zero downloads with removal of the model, I would never have bothered posting it.  And yet, much to my surprise, so far 7 people have downloaded it in a relatively short period of time.  Nearly all of my catalog is similar niche models that I made entirely for my own use, and posted in case others might find them useful.  I don't see where removing any of them from the site would serve a useful purpose.
https://www.printables.com/@Netpackrat/models
Veröffentlicht : 21/03/2025 10:34 am
Netpackrat
(@netpackrat)
Posted by: @mreuser
Remixes shouldn't count as a "model upload." Maybe make a new badge called "mix master" for that?
I disagree with this; there is already a category called "reupload" for models with insignificant changes, which accrues the uploader zero Prusameters.  I have one model in this category that I made a very minor cosmetic change to, and so far it's been downloaded 40 times, so at least some people have found it to be beneficial.  And anything that discourages legitimate remixes is going to be bad for the community as a whole, since remixes and modification are at the heart of the open source reprap movement.  Another example....  The Voron group releases the Voron 2.4 printer and all of the associated CAD as open source.  Sumdood comes along, and decides that it would be a really great idea to put a hinged door in the skirts, for storage of Revo nozzles.  He uploads it including the CAD files.  Later on, I build a Voron 2.4, find Sumdood's mod, and think it is a great idea, but...  I identified and solved several problems with the design, and published my version along with the CAD files.  Shortly thereafter, Sumotherdood makes a suggestion for an improvement, which I make, and then he builds upon my version by modifying it to match another user's cosmetic modifications of the stock V2.4 skirts.  Everybody is happy with how this turned out (including the original designer of the mod, who had good things to say about my fixes), everybody involved has gotten what they want, and given credit to those who came before them.  Open source wins again.
Veröffentlicht : 21/03/2025 11:02 am
Eds_3D_Odyssey
(@eds_3d_odyssey)
I’m thinking at least 1 download per year would be a good compromise.
All models should need a picture of the model printed. Sorry, if you’re too lazy to take a picture, I’m too lazy to download your model.
https://www.printables.com/@Eds3dOdyssey
Veröffentlicht : 21/03/2025 1:36 pm
MrEUser
(@mreuser)
Mitglied
I find it interesting that you disagree with me while providing my use case. I didn’t say remixes shouldn’t count towards Prusa meters. I said they shouldn’t count as model uploads, because they’re not. They should be recognized as what they are. This wouldn’t discourage anything. If anything, it would reward people that are good at remixing with specific recognition for what they’ve done.
Open source would still win, people would still get credit…
By seeing that something is a remix I can know to look for the original model if I need to. I may need to make edits that would be easier on the original than on the remix.
Diese r Beitrag wurde geändert Vor 1 year 2 mal von MrEUser
Veröffentlicht : 21/03/2025 6:29 pm
Netpackrat
(@netpackrat)
Posted by: @mreuser
You're trying to solve a problem which doesn't exist, and all it would accomplish is to discourage uploaders from classifying their models as remixes, so less credit would be given to original authors.  And first you would have to get everybody to agree on what constitutes a remix, and probably no two uploaders will have quite the same definition.  Does it have to start with an original model's CAD file to be a remix?  Or is copying a feature from another model enough to make it a remix?  How about a clean-sheet model that is designed to fit or work with an existing model?  Or a printable replacement part for something originally manufactured by some other technology?  It would annoy me for my upload of a gearbox vent plug for my MGA to be disqualified as an original model, because it was modeled after an original produced out of metal in Abingdon, Oxfordshire 67 years ago.
In the example I gave in my previous post, NONE of the Printables users who have uploaded their own versions would get credit for the mod (including the originator), because the source was the Voron project CAD. Even though it was heavily modified to add features, and fulfill a function which doesn't even exist in the original.
And then, what about things like Gridfinity?  Some are obvious remixes, but many others are clearly original ideas that just happen to have been made compatible with that system.  All of my own Gridfinity stuff started with a blank screen, and while I uploaded the models as remixes to give credit to Zach Friedman, most of it is completely original other than being designed to work within his storage system.  Take away model credit for such models that are uploaded as remixes, and all you will accomplish is to drive users to upload them as the original works that they really are, and discourage giving credit to those who may have only contributed ideas, which IS damaging to open source.
And what's the end goal, anyway?  Who is going to enforce it?  If it will be enforced by a bot/algorithm, who is going to handle appeals when the bot inevitably screws it up?  Is Printables supposed to then employ people to search for models that were actually remixes, where the uploaders successfully evaded the bot?  Can't we find some other problem that's actually a problem, to solve?
Yeah, there are a lot of BS models on the site, and probably you'll find other users who think that they are useful, and not BS models.  Yeah, in principle I agree that if an uploader can't be bothered to actually print and post a picture of the physical unit, then it probably shouldn't have been uploaded in the first place. Yet enforcement of even that could discourage uploading of useful stuff.  I have a couple of models where I have uploaded versions to use alternate hardware, because I thought that not everyone would want to use the same hardware that I did.  I didn't print those versions, because I have no use for them and it would have wasted my material and print time.  But, somebody may have found them useful.  I can't know one way or the other, because the website doesn't make that level of detail available in terms of download data because I lumped all the versions into the same model.  If I had to worry about those versions being auto-deleted then I wouldn't have bothered, so the end user loses.  And again, who is going to enforce it, and to what standard?  I think most of us probably overestimate the resources that Prusa can devote to operating Printables in the first place.
Veröffentlicht : 21/03/2025 9:06 pm
MrEUser
(@mreuser)
Mitglied
“all it would accomplish is to discourage uploaders from classifying their models as remixes, so less credit would be given to original authors.”
Why? Why would anyone be discouraged when what they are doing is labeled correctly? You haven’t given any reason for that to be the case.
“And first you would have to get everybody to agree on what constitutes a remix”
We already understand what it means.
“probably no two uploaders will have quite the same definition”
If there’s no consensus on what the term means, why is it used? It’s worthless as a term if there’s no clear definition.
“Does it have to start with an original model's CAD file to be a remix?  Or is copying a feature from another model enough to make it a remix?  How about a clean-sheet model that is designed to fit or work with an existing model?  Or a printable replacement part for something originally manufactured by some other technology?  It would annoy me for my upload of a gearbox vent plug for my MGA to be disqualified as an original model, because it was modeled after an original produced out of metal in Abingdon, Oxfordshire 67 years ago.”
“Does it have to start with an original model's CAD file to be a remix?”
Definitely a remix isn’t it? As in there is no doubt that in this situation, where you took someone else’s plans and made a modification directly to the plans, that qualifies as a remix in every sense, correct? Or are you going to try and invent some edge case? Because in any term in an analog language there is ALWAYS an edge case which according to you would mean we can’t use words to mean anything… let’s stay out of absurd, shall we?
“Or is copying a feature from another model enough to make it a remix?”
I’ll give you a great example. If I make a tray that is the same dimensions as one that exists in my Klein ModBox… that’s a clone. If I change the color, that’s a clone of a different color. If I adjust the dimensions, that’s a copy. If I add a feature, that’s a remix. Doesn’t matter where I got the feature from, I have remixed the original design to include another feature.
“How about a clean-sheet model that is designed to fit or work with an existing model?”
That’s compatibility. That’s new, not a remix. “But isn’t that feature compatibility.” Yes, it is, from a clean sheet model. If it was compatibility ADDED to an existing model (your own or someone else’s) that would be…
A remix.
It was simple to explain… where’s the “discouragement?” How is this hard?
“In the example I gave in my previous post, NONE of the Printables users who have uploaded their own versions would get credit for the mod (including the originator), because the source was the Voron project CAD. Even though it was heavily modified to add features, and fulfill a function which doesn't even exist in the original.”What do you think you mean when you say, “get credit for?” They uploaded something that was based on something else, someone else’s work based on your example. Here’s how it would work…The original part exists somewhere (or it’s original idea, right)? So it’s possible to link to where the original part is, correct? That’s how HTML works right? Anyone that sees an original part can provide the source and select “remix.” Then they save their work to printables. The original designer “get’s credit,” which is important, like providing sources is important in anything you publish, AND the remixer gets credit. They are in essence saying, “this is what I started with, and this is what I made out of it.” How is the person remixing the original work NOT getting “credit?” You really need to explain what you’re talking about.Because all I see is you trying to find a problem for a solution.
To END this, the problem being solved is what I’ve already described. CITATION. Citing the work you are building upon. It matters.
Do me a favor. Calm down, think this through, and realize that you are fighting this for no reason, when there is a solidly good reason to implement it.
Veröffentlicht : 02/04/2025 4:41 pm
MrEUser
(@mreuser)
Mitglied
“I disagree with this; there is already a category called "reupload" for models with insignificant changes, which accrues the uploader zero Prusameters.”
How little change is required to be “insignificant?” Resizing? Change in filament type? Change in color? All three at the same time? When does insignificant cross into, “significant?”
This is the same argument you’re making here:
The difference I’m advocating for is that “remix” STILL GETS PRUSAMETERS (YOU GET “CREDIT,” based on what I understand of “credit,” though you are arguing this isn’t the case). And you’re arguing against it. You’re satisfied with an undefined option to get nothing, but DEFINITELY not okay with an option that get’s you something because, as far as I can tell, YOU don’t understand the meaning of “remix” when it’s used.
Diese r Beitrag wurde geändert Vor 1 year von MrEUser
Veröffentlicht : 02/04/2025 4:51 pm
jameswood32
(@jameswood32)
Mitglied
Prusa badges and rewards are part of the PrusaPrinters community gamification system that recognizes user contributions like sharing prints, participating in contests, and helping others. You earn badges for activities like uploading models, writing blog posts, or gaining followers. These can sometimes unlock discounts, recognition, or exclusive rewards. It's a fun way to stay active in the 3D printing world.
I am James Wood a Content Writer.
Veröffentlicht : 18/04/2025 8:51 am
Eds_3D_Odyssey
(@eds_3d_odyssey)
Posted by: @netpackrat
There’s a big difference between not printing and uploading pictures of every version of a model and not printing and uploading any pictures. Printables should make people upload at least one picture showing the model printed. If you have versions that you haven’t printed you can tell people that in the model’s description and they can decide if they want to download them or not.
Another reason to make people upload pictures is maybe it would slow down the number of AI models on Printables. I wish people would stop rewarding the AI models with downloads or at least don’t “Like” a model until you have tried printing it.
My guess is Prusa is letting the users do most of the policing. It seems like anything’s goes on Printables until enough people report it then they react. I could be wrong???
Veröffentlicht : 25/04/2025 1:11 pm
Eds_3D_Odyssey
(@eds_3d_odyssey)
I have an idea for a new badge. Give people points for reporting models that are breaking the rules. If Prusa is going to use us to help police Printables then let us earn badges for it.
Prusa would have to give us a list of rules so we know what to report.
You get one point for every model that is removed.
You lose a point or 2 if a model is not removed. If you don’t do this people will go wild and report everything.
Years ago I was a member of a website that did something like this and it worked very well. If Printables was already doing this I would probably be at level 10. I really hate model thieves!!!
Veröffentlicht : 25/04/2025 1:23 pm
dbv
 dbv
(@dbv)
I was thinking and wondering why spare-parts and things like nozzles, etc are not part of the rewards program. I occasionally look through my possible rewards, but nothing is yet really triggering me to exchange my points for an award. So far I'm just collecting the points.
But if other thinks like nozzle, sheets, basically most of the stuff from the shop would be a part of that or you could use some points in the shop for a defined amount of money/value, that could be an incentive to use them more often.
Is that a bad idea?
Veröffentlicht : 19/05/2025 8:44 am
Pedja
(@pedja-2)
Mitglied
I just noticed that  for my last three uploaded models did not received any prusameters.
Did I do something wrong?
Please advice.
Thank you in advance
Diese r Beitrag wurde geändert Vor 9 months von Pedja
Veröffentlicht : 31/07/2025 1:48 pm
Posted by: @pedja-2
Please advice.
You did not indicate the models you are referring to, or your account name on Printables. Did the models reach 30 downloads within a 30-day period? The total number of downloads is not relevant for the purpose of awarding Prusameters; the internal "rewards counter" gets reset every 30 days.
https://www.printables.com/prusameter
Veröffentlicht : 31/07/2025 2:43 pm
Pedja
(@pedja-2)
Mitglied
Sorry my bad. @Pedja_602439. It is about reward related to model upload. I did not see any reward for:
Clips for hood bonet insulation
Wireless Charger Stand - Charging Dock
Two piece locking panel clip for Bosch Rexroth with profile slot 6mm
ND filter StepUp adapter 52mm/55mm
Kids Watch band
Jabra Evolve 75 Dock
Veröffentlicht : 31/07/2025 3:01 pm
Ah, ok. You only get Prusameters directly upon uploading for the first 10 models you upload. After that, only points for likes and downloads are awarded.
Veröffentlicht : 02/08/2025 5:43 pm
Pedja
(@pedja-2)
Mitglied
I noticed but after I address q. Thx
Veröffentlicht : 02/08/2025 5:47 pm
Muhammad Bilal Jack
(@muhammad-bilal-jack)
Mitglied
Prusa Badges and Rewards are part of a community program:
Badges;Earned for activities like sharing prints, helping others, or beta testing.
Rewards;Points can be redeemed for discounts, merch, or filament.
Veröffentlicht : 04/08/2025 9:31 am
Micheal Abroy
(@micheal-abroy)
Mitglied
I want to know how Prusa Badges and Rewards work — how to earn them and what they can be used for.
Veröffentlicht : 04/09/2025 6:00 am
Seite 18 / 19
