[Solved] Problems with the G-Code
martinillou
(@martinillou)
I have the prusa i3 CTC pro B, and I have a problem with the G-Code, because of the velocity. The default G-code in the prusaslicer is:
G1 Z5 F5000 and i had to change the code to F100 in the printer configuration-personal G-code.
The problem appears when I export the GCode, because the line which the struder back to the heat bead is too fast. The first line is ok, because I changed manually, but the second is created automatically.
How can I change it? I'd like when I'll slice the second line in red, instead of F7800.0 will be F100.
Thanks in advance.
Best Answer by Neophyl:
Have you answered your own question ?
Anyway if you still have an issue please read this thread in the Prusa Slicer sub section https://forum.prusa3d.com/forum/prusaslicer/initial-movement-speed-crashing-z-axis/
That move is the move to the start of your print and it is classed as a travel move, as such its moved at the travel speed.  Z cant do the normal travel speeds but there is NO separate travel rate for purely z moves unfortunately.  On a different thread on github it was pointed out that your machine firmware should be limiting the actual travel move on z no matter what slicer says to move at.  SO I would check what your machine limits are set to in both Slicer (in case its sending them to the printer) and also in your printers eeprom settings in firmware.
Napsal : 24/07/2020 1:20 pm
martinillou
(@martinillou)
RE: Problems with the G-Code
Posted by: @martinillou
Thanks in advance.
I'd would like to know how to change the speed of the z movements.
Napsal : 24/07/2020 1:28 pm
Napsal : 24/07/2020 1:45 pm
1 lidem se líbí
martinillou
(@martinillou)
@neophyl
The problem was that you said.
Thanks, I saw the answer in other forum. But thanks anyway!
Napsal : 25/07/2020 9:04 am
