Problem with filament flow directly after color change
Johannes
(@johannes-7)
Mitglied
Hello everyone,
I'm experimenting with color change / mid-print filament change at the moment (Prusa Core One). The printer requests the filament change, and I change it. After the purge I remove the residual filament from the nozzle, and then press yes to the question if the purge is okay and that continues the print. On its way to the print, filament already flows out of the nozzle, which then has the risk of destroying the print in some way.
How is this supposed to work?
Veröffentlicht : 18/05/2025 3:27 pm
Sembazuru
(@sembazuru)
RE: Problem with filament flow directly after color change
That extra purge when the printhead is returning to the print is normal for Prusa printers (since the MK3 in my experience, maybe earlier). AFAIK it is a pressure prime. What I (and many others) do is I don't remove the color change purge right away, rather I use it as a handle to hold onto the pressure prime extrusion. Then when the nozzle starts to lower towards the print I yank it all off.
See my (limited) designs on:
Veröffentlicht : 18/05/2025 4:32 pm
Johannes
(@johannes-7)
Mitglied
Hm, I guess that means the "stop on door open" feature is then basically incompatible with changing filament mid print.
In any case, thanks for your answer!
Veröffentlicht : 18/05/2025 5:13 pm
strjan
(@strjan)
There is thread on manual colour swapping with MK4/s. With that, you print typical purge tower, which takes care of all the problems with the filament swap.
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-how-do-i-print-this/how-to-print-multi-material-models-without-an-mmu-tutorial/#post-734746
I see no reason, why it shouldn't work with Core One.
Veröffentlicht : 19/05/2025 3:54 pm
Wondrej
(@wondrej)
Mitglied
excactly I have this issue too.
The safety feeture (that was force-added on latest update) simply removes any option on manual removal of the droop just before it touches the print, since it moves the print head to home possition every time you open the door.
I would love to know solution to this other than playing with g-code. Right now I am priting pretty tall and narrow print and printing purge tower of same height is also not ideal (also when i tried it last time, I wasnt able to force the printer to start the shape that was suppose to be there for purging)
Veröffentlicht : 27/04/2026 7:03 pm
