Printing PLA and change to FLEX
ufaak
(@ufaak)
Hello,
is it possible to start printing with PLA filament, and then (for example in 10. layer) change filament to TPU?
Thank you
Publié : 13/07/2022 8:01 pm
JustMe3D
(@justme3d)
RE: Printing PLA and change to FLEX
Should not be an issue. Pre-set a filament change in Prusa Slicer and then change the filament when the printer asks you to. https://help.prusa3d.com/article/color-change_1687
You´ll just have to dial in the new temperature manually then to correspond to the new filament´s requirements and to hope that TPU properly sticks to PLA.
Cheers
Chris
Publié : 13/07/2022 8:39 pm
ufaak
(@ufaak)
Thank you @justme3d
I think about set up two extruders and enable "Single extruder multi material" - then I should be able to set different filament profiles for each extruder.
But my question is more about the materials. How strong will be connection between PLA and TPU?
Publié : 13/07/2022 9:00 pm
Swiss_Cheese
(@swiss_cheese)
@tomas
Not great between PLA and TPU/TPE, you will do better using PETG, ABS, ASA, or PC with TPU/TPE. <--(that's not an all inclusive list) and of course it depends on the qualities of the products your using.
PETG is the next easiest to print and bonds reasonably with TPU/TPE
Regards
Swiss_Cheese
The Filament Whisperer
Publié : 13/07/2022 9:32 pm
ufaak
(@ufaak)
Thank you @swiss_cheese.
I will try both and then will make a decision.
Publié : 13/07/2022 10:07 pm
Swiss_Cheese
(@swiss_cheese)
Publié : 13/07/2022 11:21 pm
brucce tran
(@brucce-tran)
Posted by: @justme3d
Should not be an issue. Pre-set a filament change in Prusa Slicer and then change the filament when the printer asks you to. https://help.prusa3d.com/article/color-change_1687/ Penalty Shooters 2
Cheers
Chris
i wish i just had to dial the new temperature manually like you said. Then to match the requirements of the new filament and pray that the TPU is suitable for PLA. It's really bad luck, isn't it?
Ce message a été modifié il y a 4 years par brucce tran
Publié : 19/07/2022 7:07 am
This model uses TPU as a hinge. I was worried about TPU Temperature differences, and in the end, it was the white PLA which gave problems
the white was an unknown brand, and I eventually printed it at 170C to prevent strings
the Black, was a no name TPU.
Publié : 19/07/2022 11:46 am
