Printables unable to Publish after Edit / Support Access Missing
Carter
(@carter-3)
I can not publish models that I edited.  Specifically, I added a warning sentence to a description of a number of models, saved as a draft and then attempted to Publish... no model returned as published.  Also I can not find any access to a support function.
Best Answer by FoxRun3D:
Most importantly, the field where it says it's a new model or a remix. This has happened to me every time I edited an older model.
Napsal : 26/01/2023 2:46 am
adesir
(@adesir)
RE: Printables unable to Publish after Edit / Support Access Missing
If  you edit models published some times ago, you have to fill some new fields before publishing again. Double check all the required fields, old and new.
Mes modeles publics
Napsal : 26/01/2023 6:24 am
Carter se líbí
Napsal : 26/01/2023 11:41 am
Carter se líbí
Carter
(@carter-3)
That was it... "new model" should be changed to "original work"... if after editing a model that has been shared but simply getting edited..
Thanks.
also... what happened to access to support for the site?  There used to be an icon on the side of the window that allowed comment or questions.
Napsal : 26/01/2023 3:25 pm
Extra Fox
(@extra-fox)
Been wondering that myself, but you DM mods here and they can get your question over.
I had a model completely disappear off the site with no explanation. So I'm curious if I can just re-upload it or if I ran afoul of some arcane rule.
P.S. I'm a big fan of your Rasberry Pi cases, they work really well.
Aaron
Napsal : 26/01/2023 6:50 pm
