You offset your Z Axis: Poll is created on Oct 07, 2022
Poll: How do you offset your Z Axis?
9cento
(@9cento)
The title says it all
Opublikowany : 07/10/2022 4:21 pm
RedDawg
(@reddawg)
RE: Poll: How do you offset your Z Axis?
You forgot a viable option: The build plate itself. I frequently use a textured plate that I coated one side with a replacement PEI sheet. My theory was that I could flip the sheet to one side or the other, depending on whether I wanted the first layer of the build to be smooth or textured, and I wouldn't have to adjust the Z offset since the total thickness of the plate was exactly the same no matter which side was up (or down). Surprisingly, I found that when the textured side is up, the offset needs to be closer to the plate (by about 0.1mm) than when the smooth side is up. So I  still need to change the offset even though the build plate thickness hasn't changed. With that caveat, I find that the offset is relatively independent of the type of filament loaded or other factors.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Opublikowany : 08/10/2022 2:40 am
9cento
(@9cento)
Well I took that for granted given the fact that it's the very first reason to adjust the Z Axis
Opublikowany : 08/10/2022 3:55 am
