piece that has to float in gasoline
maximo weintraub
(@maximo-weintraub)
Hello, I was trying to make a piece that has to float in gasoline, I already tried it with PETG and it didn't float, so the question is. Do you know of any filament that floats in naphtha and lasts? I'm using google translate, if you don't understand something ask me haha
Best Answer by Artur5:
What Zoltan said. Apart from resisting the chemical action, this part should be perfectly sealed because gasoline is less dense than any filament. In order to float it must be hollow or at least with a low infill percentaje. If it isn’t gasoline tight, it won’t float for long.
I’d suggest nylon. Good chemical resistance and low density, which makes it easier to float. Polypropylene is even less dense and would do also for gasolines with high aromatic content but not for non-leaded gasoline.  TPU filaments wouldn’t be my choice. More more dense than nylon or PP and chemically incompatible with most gasolines.
Posted : 05/06/2022 4:57 am
Zoltan
(@zoltan)
Member Moderator
RE: piece that has to float in gasoline
Your model must be hollow and water (gasoline proof)
Posted : 05/06/2022 5:22 am
Swiss_Cheese
(@swiss_cheese)
@maximo-weintraub
https://ninjatek.com/wp-content/uploads/NinjaFlex_CR.pdf
https://ninjatek.com/shop/ninjaflex/
Enjoy
Swiss_Cheese
The Filament Whisperer
Posted : 05/06/2022 6:15 am
Artur5
(@artur5)
Posted : 05/06/2022 8:09 am
Netpackrat
(@netpackrat)
A lot of plastic carburetor floats are made from a material with a trademarked name of Nitrophyl.  I would start by trying to find out if that matches up with a generic type of plastic, and if so, whether or not it is available as a filament.
https://www.printables.com/@Netpackrat/models
Posted : 05/06/2022 2:04 pm
