Pictures standard bigger in forum
Peter M
(@peter-m)
To the forum admin:
Please set the pictures standard bigger for the forum, now we have little pictures where we cannot see the info we need.
I know it can be set bigger but nobody knows this.
Opublikowany : 03/06/2019 3:46 am
RE: Pictures standard bigger in forum
Peter - all a person needs to do is to change the Link To: setting when posting to Media.
Or, if you are viewing a post from someone and they didn't do this, open the image in a new tab, and edit the URL to remove the -300x200 or whatever the last characters are. That gets you the full image resolution.
That said, the default should be Link to Media and not Link to None.  However, no Prusa employee monitors this forum on any regular basis (except to remove derogatory or other posts the don't want to see), therefore you are on your own.
Opublikowany : 03/06/2019 5:16 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Posted by: tim-m30
Generally it's moderators who check posts.  Any faults posted are also noted by moderators and reported back.
The forum fault list is still quite long, but it is now reducing on a daily basis.
Peter
Opublikowany : 03/06/2019 7:48 am
I see today the developers have turned bold back on for new posts.   At least some progress is being made... but post tracking is still woefully inadequate compared to the old forum.
Opublikowany : 03/06/2019 8:09 pm
