Paint on Seams vs a not as of yet Custom seams
Hello Prusa Members, I been using the new v2.4 win 64 for about 2 weeks now. It's a big improvement for 3d printing. I don't know but, only wish that the "Paint" on Seams had a few other variables options to either start at the top of a part and be vertical to the bottom in a straight line or at a specified angle that would be a game changer with seams. Hoping others will ask about this to see if it is plausible. I know about the other options on seams nearest, aligned etc... But if seams could be dictated as you want... Wow that would be nice.
Try this
@trobert6724
I'm pretty sure someone has already made a feature request for this on GitHub, and I agree it would be a great feature, just like in PhotoShop ( the original PS) you can hold down shift and click point A then click point B and and a straight line drawn between them.
While PrusaSlicer does not have such a feature currently, it is extremely easy to draw a straight line using your mouse against something straight, I do this commonly and without issue, if you want a certain angle you can rotate the part to that angle and draw the line.
I made these in seconds, no fuss no muss, using the side of my caliper case (the nearest straight edge to me) at the time of reading your post.
I would also like to see such a feature, however I would like to see some other things working first.
But maybe this will help you for now.
Swiss_Cheese
The Filament Whisperer
RE: Paint on Seams vs a not as of yet Custom seams
...so what do you do if you use a trackball? ;p
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Thank You Swiss Cheese, You are on point with this. That is on a wish list with Prusa slicer. It would help Point A to B or just vertical path ect... It's a better way of making a seam. Painting a awkward path but is okay, but being accurate is better.. We will see if this can go forward to the team.
I'm not sure. I only have a basic mouse..
@chris-laudermilk
Plug in a mouse 😛
I knew that would come up 😉
There are indeed several requests on Github (including from yours truly) for just that feature.
