Oversized pieces
After a long time tweaking my new 3D printer I solved all the unexpected errors and I can print succesful pieces but I am facing a "problem", they are over sized, I found this problem trying to print a Raspberry Pi Case and an smartphone case, the printed pieces are bigger than the objects.
Here some related information
Printer: Geeetech Prusa i3 Pro B
Firmware: My GitHub (Marlin)
Software: Repetier Host with Slic3r
Does somebody know how could I solve it? Thank you very much
Ce sujet a été modifié il y a 5 years par Eleanor dane
Publié : 01/03/2021 4:05 am
RE: Oversized pieces
I suggest you ask Geeetech, since it's their printer, not a Prusa printer.
Publié : 01/03/2021 3:35 pm
Is everything oversized when printed, or just files you slice?
If everything, look into adjusting steps-per-mm for each affected axis.
Publié : 01/03/2021 6:33 pm
