Outdoor linear bearing
adam.b5
(@adam-b5)
I need some advice.  I am finishing up an out gazebo in the northeastern US.  The structure has a clear acrylic roof that is UV blocking.  The sides are screen material.  I am making some linear bearings that will slide along 1/2 EMT conduit to open and close doors that will house a TV.  Essentially, I am making a pair of "barn doors" where the doors will hang from the 1/2" conduit with 2 bearing on the top of each door to allow them to slide.  Temps here range from 0-100 degrees Fahrenheit.  What would the best material for the prints.  I had some PLA out in the sun this summer and the heat warped the PLA.  The bearings I am making would not really be in direct sunlight nearly as much as the PLA I had previously left outside, but I think in the summer, the bearings would get pretty hot and I think they might deform which would prevent them form sliding along the conduit.  Any suggestions?
Veröffentlicht : 28/09/2019 7:29 pm
RE: Outdoor linear bearing
Nylon
Veröffentlicht : 28/09/2019 7:52 pm
Ilikestuff
(@ilikestuff)
I would suggest that the PLA wouldn’t last very long and then wouldn’t slide along the conduit, maybe a different filament type would work that is more temperate resistant like ABS or PETG. You may even want to go with something like ASA which is UV resistant.
Veröffentlicht : 28/09/2019 7:55 pm
rmm200
(@rmm200)
If you would, show us a picture of the bearing. I am having trouble visualizing a linear bearing here.
Veröffentlicht : 28/09/2019 8:07 pm
adam.b5
(@adam-b5)
Here is the image
Attachment removed
Veröffentlicht : 28/09/2019 8:35 pm
Posted by: @adam-b5
Here is the image
Attachment removed
Well - my vote changed - now I'd say even nylon won't work. I was originally thinking a typical barn roller.  Now I'd say maybe Delrin (POM) if and only if the rod it is moving on is machined steel - otherwise, good luck. Way too much surface for a loaded non-rolling bearing.
Veröffentlicht : 28/09/2019 9:27 pm
adam.b5
(@adam-b5)
I should have mentioned, the "doors" being supported are ~14"x39" and weigh about 2 lbs each (roughly)
Diese r Beitrag wurde geändert Vor 7 years von adam.b5
Veröffentlicht : 28/09/2019 9:55 pm
Steve
(@steve-3)
Does it have to be 3D printed?  My suggestion is to buy a block of nylon or Delrin and do some simple machining.  You could also try a Trex deck board that is designed to be in the sun all day.
Steve
Veröffentlicht : 28/09/2019 11:22 pm
