No Power to Heat Bed
Grandpa Joe
(@grandpa-joe)
I have MK2.5s and it has lost power to the heat bead.
  • All connections tight
  • All cables checked - no damage.
  • Connections to Rambo board are tight and secure.
  • Voltage to Hot end is 12 volts
  • Voltage to heat bed is 3.4 volts
I detached heat bed power cables from Rambo Board and checked the poles inside the connector -  3.4 volts
I detached the heat bed power cables and tested the poles inside its Rambo attachment. -  12 volts.
Prusa tech chat says Rambo Board needs replacing.    Prusa doesn’t have one, and their supplier in the US doesn’t have one.   Does anyone out there have any ideas or suggestions ?
Opublikowany : 29/04/2022 8:59 pm
RE: No Power to Heat Bed
Did you check all of the fuses?
Opublikowany : 01/05/2022 1:42 am
Grandpa Joe
(@grandpa-joe)
Yes, all fuses are fine.
Opublikowany : 01/05/2022 4:29 pm
I would check the internal resistance of the heating bed. The value should be around 1 Ohm (12V). If the resistance deviates significantly, the heating bed may be defective.
https://help.prusa3d.com/article/multimeter-usage_2117 (see table).
wbr,
Karl
Opublikowany : 01/05/2022 8:08 pm
