No g-code/config import to prusaslicer 2.0 - if 2.0 have made the g-code
8orge
(@8orge)
Have this weird  problem with the new Prusaslicer 2.0 ,
i have generated a g-code file with 2.0  and want to import
this g-code file again ,then i get this message :
Not a Slic3r generated g-code.
The old g-codes i made with slic3r version prior to 2.0
imports just fine just not the ones it have created itself .
 I did find a solution to this problem :
The only difference between the old g-codes and the ones
from the new 2.0 is this in the start line of the g-code :
The old slic3r          ; generated by Slic3r Prusa Edition 1.41.2+win64 on 2019-04-18 at 22:29:37 ;
The new 2.0            ; generated by PrusaSlicer 2.0.0+win64 on 2019-05-22 at 23:02:56 ;
If you change the   PrusaSlicer    to  Slic3r Prusa Edition  it will now import the 2.0 's
own version  .
So is this a software problem or is it something i am mayby doing wrong ?
Ce sujet a été modifié il y a 7 years 3 fois par 8orge
Publié : 25/05/2019 6:17 pm
RE: No g-code/config import to prusaslicer 2.0 - if 2.0 have made the g-code
Can confirm this is an issue. It would be great if you could create an issue for this on Prusa's GitHub page for PrusaSlicer. Good catch!
Publié : 25/05/2019 8:50 pm
8orge
(@8orge)
Thank you for confirming this issue with PrusaSlicer ,will post it on Prusa's Github page .
Publié : 25/05/2019 10:32 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
It will be fixed in the next release.
Publié : 03/06/2019 4:01 pm
