MMU3 or INDX
FullMetalJumper
(@fullmetaljumper)
MMU3 or INDX
I'm contemplating getting the MMU3 for my Core One + as I'd like to multi-colour print but waiting for INDX (which I imagine if the most sensible option) is killing me.
From what I can gather, the users that managed to sign up for the first round of INDX are still waiting for their units. If I manage to get into the 2nd round of orders (whenever that happens), I could be waiting months to get it.
Lastly, if I did cave in and get the MMU3, are they reliable with the filament changes? I had the MMU2 back when I had the MK3s and it was terrible. Constant jammings. Don't want to spend £300+ just for a headache.
Postato : 26/02/2026 10:55 am
jim65richards
(@jim65richards)
Utenti
RE: MMU3 or INDX
Prusa overhauled the firmware and physical sensors, meaning it actually recovers gracefully from errors rather than just "giving up" mid-print. While the INDX is the more elegant, integrated solution for the Core One, the MMU3 is a proven workhorse today if you can't stomach the indefinite wait. Just keep in mind that with any single-nozzle swapper, success still hinges on your filament tip shaping and keeping your dry boxes sorted—but the "constant jamming" days of the MMU2 are largely a thing of the past.
empowerretirement login
Postato : 26/02/2026 11:57 am
2 persone hanno apprezzato
RE: MMU3 or INDX
I would wait, even if it is tough.
I don't have an MMU3, but by all accounts it is working but can be a bit finicky. The "buffer" system to manage retracted filament (open loops in flat cages) takes up extra space and makes loading new filament somewhat tedious. While filament switching during prints is more efficient, regarding both time and filament waste, than Bambu Labs' AMS, the INDX will be much better in both regards. INDX should also handle difficult filaments like TPU better, and will allow you to change nozzle sizes during a print -- if and when the slicer supports that.
Count it as a blessing that you won't be part of the first wave of INDX users (who are definitely bracing themselves for some troubleshooting...), and find some nice single-color models to print for the next couple of months. 🙂
Postato : 26/02/2026 1:32 pm
1 persone hanno apprezzato
FullMetalJumper
(@fullmetaljumper)
RE: MMU3 or INDX
Thanks Jürgen. I do like the idea of different nozzle sizes so waiting will be the best option I think. Hopefully the first wave users won't have too many issues.
I got the impression that the batch was sold and had already been delivered and we were just waiting for more stock. Was surprised to see that they hadn't shipped and apparently still working on the final design.
Postato : 26/02/2026 1:50 pm
RE: MMU3 or INDX
Yes, it seems that both, Bondtech and Prusa, are still busy. Probably (hopefully!) optimizing the manufacturing process at Bondtech, and certainly finishing the firmware and slicer changes at Prusa. Bondtech support confirmed to me last week that the firmware is still under development, and that specifically they could not say yet how mounting and calibrating a different nozzle would look in detail.
Postato : 26/02/2026 2:10 pm
Artur5
(@artur5)
RE: MMU3 or INDX
I said it before, guys, don't hold your breath waiting for the INDX. In all likelihood, it will take quite a long time before it becomes a troublefree reliable product. Besides, when (if) it does, we must realize than adapting/modifying an existing design to this system it will never be as smooth, compact and economical as designing a multitool changer from scratch. See for instance, the infamous Snapmaker U1. It isn't what you'd call a high end model by any means, but seems to work fine, it's small and affordable ( both on initial cost and spares ). INDX systems based on Prusas (or Vorons ) will be really huge machines, specially if fully enclosed. Besides, spool management will be a PITA, I suspect. So much tubing, cabling, spools everywhere and what not. A PITA for everyday work and maintenance. Not my idea of an ergonomic printer.
Postato : 26/02/2026 3:08 pm
RE: MMU3 or INDX
Posted by: @artur5
[...] adapting/modifying an existing design to this system it will never be as smooth, compact and economical as designing a multitool changer from scratch. See for instance, the infamous Snapmaker U1. It isn't what you'd call a high end model by any means, but seems to work fine, it's small and affordable ( both on initial cost and spares ). INDX systems based on Prusas (or Vorons ) will be really huge machines, specially if fully enclosed. Besides, spool management will be a PITA, I suspect. So much tubing, cabling, spools everywhere and what not. A PITA for everyday work and maintenance. Not my idea of an ergonomic printer.
Where do you see the difference, in terms of package size and filament management, between the Snapmaker U1 and a Core One with INDX? They both use side-mounted spools as the factory solution, they both use individual curved PTFE tubes on top to guide the filament. (Snapmaker's seem taller than the ones on an INDX-equipped Core One.)
No question that the Snapmaker is cheaper, like all the Chinese options. Regarding performance (speed, print quality), the jury is still out since neither solution is shipping yet.
Postato : 26/02/2026 3:16 pm
Artur5
(@artur5)
The Snapmaker U1 has hit the market already. Lots of reviews and unboxings on the net. Granted that many of these are just marketing hype or addressed to clueless users, but fact is that the machine seems to work without major issues right now. INDX systems who knows when they will be available for real.
Apart from that, IMHO, the main ergonomic difference between a printer designed from scratch to be a multitool changer ( Prusa XL/Snapmaker U1 ) and adapting INDX to existing printers is that the printheads of the XL/U1 are located at the back and the INDX are at the front, which is a big contrivance for accessing the inside of the printer, removing the plates, watching the print jobs or doing maintenance.
The only solution would be to redesign totally the gantry so that the printhead was mounted at the back of the X axis instead of at the front. Not impossible, but I wonder if it’s worth the time/cost involved and it wouldn’t be better to make new machines specifically designed for the INDX from the start and forget adapting current printers,
How would you name those printers ... Prusontech, Bondusa ,Vortech, Bondron ? 😋
Questo post è stato modificato 2 days fa da Artur5
Postato : 26/02/2026 4:42 pm
mnentwig
(@mnentwig)
RE: MMU3 or INDX
Speaking of Voron, does anybody have experience with Stealthchanger? For me it's either INDX plus a second Core One (won't touch my current MMU-equipped one as it works just fine). But then, the nagging question: why wait for a year for a "nozzle changer" when I can have a "tool changer" right now? Slightly more expensive, that's OK, but no vendor lock-in on nozzles.
The recent video makes me think - the filament changer mechanism looks absurdly heavy.
Postato : 26/02/2026 4:52 pm
RE: MMU3 or INDX
Posted by: @artur5
Regarding physical access to the finished print, I would not expect a big impact. The parked tools do not reach lower than the active nozzle, and only a small bit below the existing LED bar. (I do wonder whether there will be revised chamber lights...) Swapping tools should actually be easier due to the front parking position.
Visibility of the print in progress is indeed a concern. I am a bit reluctant to go to eight tools on the Core One INDX, which seem to block most of the view through the front door. But four is probably the sweet spot for me anyway, with four spools in a dryer (on a shelf above the printer).
Postato : 26/02/2026 5:05 pm
HappyKatz
(@happykatz)
RE: MMU3 or INDX
I'd go for the MMU3 - it's stable and doesn't have any of the nagging issues that made me constantly babysit my MMU2, and works great with ASA, PETG, and PLA.
Also, it's comparatively cheap, so even if you swap it out in three or six months for an INDX, you can use the time to get used to modeling for multi-material (assuming that you are not doing this already), and establishing a baseline for comparison on performance and quality without breaking the bank.
Just my 0.02 😉
Prusa Core One, MK4S w/ MMU3 (formerly MK4 / MMU3, MK3S+/MMU2), 2 Prusa MINI+, Octoprint. ASA, PETG, PVB, (some) PLA.
Postato : 26/02/2026 5:42 pm
Artur5
(@artur5)
RE: MMU3 or INDX
Posted by: @mnentwig
I'd say that those Stealthchanger LDO kits look interesting at first glance, but once you start adding modules, I don't know. You need a base kit; a tophat-door kit and a tool-dock kit for every printhead ( 4 or 5 ). It seems a lot of money when, in top of that, you need to purchase 4 or 5 sets of extruders and hotends ( not included with the kits ). At this point I rather fetch an Snapmaker U1. Makes more sense to me, being cheaper and almost a plug and play solution, while installing and configuring properly an Stealthchanger system sure won't be that easy. I've built several Vorons in the past, but I'm already tired of tinkering for days/weeks with this stuff. I became more and more lazy as years went by, Old age is merciless.😋
Postato : 26/02/2026 10:28 pm
_KaszpiR_
(@_kaszpir_)
RE: MMU3 or INDX
My friend got Snapmaker U1 and so far so good. Ordered at the end of the July 2025, delivered in January 2026. Now he did some test prints and they look ok, though he had some limited time to use it but surely will do more with it.
Regarding MMU vs INDX. The great thing is that you can have MMU now (where 'now' is of course delayed due to Prusa ordering/delivering process of the already existing products, though so its more about 'get it in about 4 weeks' ). You can swap to INDX later, and I assume INDX will be available in about 6+ months - and I mean the actual physical parts, firmware and a new PrusaSlicer all together, though I suspect firmware/software updates later than the hardware.  I expect the thing to be more mature around November 2026 for Formnext, unfortunately it is quite a long time to wait.
Personally I will skip MMU, and patiently waiting for the INDX because for me it is a nice to have, not a necessity, stuffed with much more features I am interested in, which are limited on MMU. Also if you cannot wait then I guess 3d printing is not the best hobby for you 😀
Another idea is to get a different printer from different brand, but that would also expand the ecosystem of tools and thus will totally change the workflow you have developed over the time, and changing habits is never easy.
Postato : 27/02/2026 7:22 am
