MK4 nozzle replacement
YigalB
(@yigalb-2)
According to Prusa's guide ( https://help.prusa3d.com/guide/how-to-replace-the-prusa-nozzle-mk4-mk3-9_421215 ), replacing MK4 nozzle requires taking out the hotend, disconnecting wires etc. This is also the guidance I got fro Prusa's tech support.
On the other hand, I can see a simpler method, which is simpler, like this:
If so simple, why wouldn't Prusa suggest it?
Publié : 07/08/2024 2:58 pm
JP Guitars
(@jp-guitars)
RE: MK4 nozzle replacement
Because some people are incredibly ham fisted and are going to break things, the recommended way is the least risky way of changing the nozzle. If you have a modicum of mechanical sympathy then the quick way if fine.
Personally I use a 13mm open end spanner to hold the block and a mini socket set to turn the nozzle, the only time I use the recommended way is if I want to switch to a hardened nozzle as a use a converter to use a V6 Nozzle and I have a spare heater block permanently setup.
Publié : 07/08/2024 3:34 pm
YigalB
(@yigalb-2)
Posted by: @jp-guitars
I would think that disconnecting the cables, pulling out the heater block while removing the cables from their hidden place, and then reverse the actions is more error prone. Also, the YouTuve video shows printed sets to help maintaining the heater block location.
I will try this, once I will get my MK4 back to work.
Publié : 07/08/2024 4:33 pm
JP Guitars
(@jp-guitars)
The biggest risk is breaking the wires due to not holding the block sufficiently, particularly the thermistor cable. But I do think Prusa are being over cautious.
Publié : 07/08/2024 4:44 pm
1 personnes ont aimé
fabnavigator
(@fabnavigator)
Changing the nozzle on the MK4 is super easy and should take no more than a minute or two at the most. I change my nozzle frequently.
1. Unload the filament.
2. Flip the fan to the side.
3. Remove the silicon sock if you have one.
4. Loosen the two thumb screws.
5. Attach the MK4 Nextruder Nozzle Change Heater Block Clamp
https://www.printables.com/model/624027-mk4-nextruder-nozzle-change-heater-block-clamp
6. Unscrew the nozzle using the Nextruder nozzle wrench V2, or some other tool of your choice.
https://www.printables.com/model/623570-nextruder-nozzle-wrench-v2
7. Screw in the new nozzle and tighten it.
8. Remove the heater block clamp.
9. Tighten the two thumb screws.
10. Reattach the silicon sock.
11. Flip the fan back into place.
Publié : 07/08/2024 8:20 pm
fabnavigator
(@fabnavigator)
Posted by: @fabnavigator
I should have mentioned that you need to wait for the nozzle to cool to room temperature after you unload the filament. Your time is still only about a minute, but if you need to unload the filament there are several minutes waiting for the nozzle to cool down.
Publié : 08/08/2024 11:12 am
YigalB
(@yigalb-2)
With Prusa mini, the nozzle should be hot while unscrewing it, in case some filament was purged.
Doesn't it have to be the same here?
Publié : 08/08/2024 12:08 pm
JP Guitars
(@jp-guitars)
Nope, mk4 you change cold
Publié : 08/08/2024 12:10 pm
JP Guitars
(@jp-guitars)
Should have said, that is because mk4 (and XL) use the nextruder
Publié : 08/08/2024 12:12 pm
YigalB
(@yigalb-2)
I am curious: why? Perhaps becauze the nozzele is one long metal piece, unlike the plastic tube leading to the nozzle with the MINI?
Publié : 08/08/2024 12:13 pm
