Mesh bed leveling pushing bed down
Flavio Segundo Ramos
(@flavio-segundo-ramos)
So , I have a problem/Question my printer prints all good, while just doing a general service to my prusa mini I decided to use the mesh bed leveling feature and the first point the nozzle probes is good , but the second point there the nozzle pushes into the bed and it does so hard that the z axis starts bending as well. But then when printing the probing works perfectly. Does anybody have similar experiences
Opublikowany : 14/03/2023 8:15 am
Antonio
(@antonio)
Member Moderator
RE: Mesh bed leveling pushing bed down
if the nozzle crash on the bed it means the pinda has been moved too high (aka the distance between pinda and bed is too high)
I'm not an expert. Ma parlo anche italiano 😉
Opublikowany : 14/03/2023 8:50 am
The pinda sensor is in the right position. The bed bending only happens in the mesh leveling , but not in the probing before printing
Opublikowany : 14/03/2023 12:29 pm
Mesh levelling IS the probing before printing.  So what do you mean when you say mesh levelling ?
Opublikowany : 14/03/2023 1:35 pm
when you go to calibration in the menu of the prusa mini you can do a mesh bed leveling
When I do that calibration the first probing Point is ok but the second go goes deep into the bed and not only does the bed bend but also the whole z axis as well
This post was modified 3 years temu by Flavio Segundo Ramos
Opublikowany : 14/03/2023 2:33 pm
Antonio
(@antonio)
Member Moderator
Try to run the wizard again.
It seems some sort of misreading on the second calibration point
Opublikowany : 14/03/2023 10:32 pm
